Fuel leak!!! HELP
Old Feb 24, 2008 | 05:28 PM
RP27G8G's Avatar
RP27G8G
Fuel leak!!! HELP
I have a fuel leak and I can't seem to get it fixed. The fueld is leaking from the top of the water/fuel separator unit. It is leaking from the connection where the square black connector is on top. I believe this is the water sensor but am not sure and don't knowhow to remove it. It is actually leaking up through the middle of the connector. Any help in fixing this will be greatly appreciated!
Old Feb 24, 2008 | 05:37 PM
sunktruck's Avatar
sunktruck
that conector is on a rubber o ring pressed from the inside of the stand you have to remove the stand and when you flip it over there is a ?brass fitting that you have to remove to get that plate off and then you should be able to remove the conector and change the o ring. Iv never done it but thats how it was explained to me and i think ford sells a seal service kit for it because i think there are a couple of other seals in it that you should probably replace if you take it apart. hope that helps.
Old Feb 24, 2008 | 05:49 PM
RP27G8G's Avatar
RP27G8G
Thanks!! I'll get it apart and take a look. From what we could see with it on the truck there was no way to get inside. Guess I'll have to tear it down and check it out. Thanks again! This is a great website with great people!
Old Feb 24, 2008 | 11:33 PM
rockcrawlerdude's Avatar
rockcrawlerdude
i had the same problem with mine as it was the actual cap that had a crack in the center of it . i used some "Seal All" from walmart on the top of it and its been holding ever since ( jb weld will do in a pinch but it eventually weakens and a bubble forms that will burst)....
Old Feb 25, 2008 | 05:27 PM
RP27G8G's Avatar
RP27G8G
The sensor? is leaking from the inside by the contact point. I called the Ford dealer today and the part is almost $160. It is the fuel pre heater. This may be part of my hard starting problem as well.
Old Feb 25, 2008 | 06:40 PM
sunktruck's Avatar
sunktruck
sorry I kind of glossed over the part about the diesel coming out the center of the conector before I pot in my 10 cents.
Old Feb 25, 2008 | 08:21 PM
rockcrawlerdude
yes that sensor cap... i used Seal All from walmart and sealed it up good...
Old Feb 25, 2008 | 08:23 PM
RP27G8G's Avatar
RP27G8G
So, is it the pre heater and if it is will it cause a problem if it isn't connected?
Old Feb 25, 2008 | 08:37 PM
PLC7.3's Avatar
PLC7.3
If you would like the filter header heater fix .......ie replace 2 orings with some disassembly required........ See post 2 down.
Old Feb 25, 2008 | 08:50 PM
rockcrawlerdude
no you cant just disconnectit as fuel is behind the cap hence the leak ( thats what i thought as well) so you either have to replace the entire assembly or use something to seal the CRACKED cap with . i used Seal All because its gas/oil resistant and so far its been holding great... now when you seal the cap and if it leaks from under the cap( not from the top where the crack is) then you'll have to use the o-ring fix as suggested in the above reply...
Old Feb 25, 2008 | 08:54 PM
PLC7.3's Avatar
PLC7.3
RP27G8G already sent info via email..............
Old Feb 25, 2008 | 09:18 PM
RP27G8G's Avatar
RP27G8G
Perfect!!! Thanks again!
