vibration w. steering wheel
Old Feb 24, 2008 | 04:06 PM
powerstroke1869's Avatar
powerstroke1869
everytime i drive and it shifts into overdrive my steering wheel has a vibration to it i dont know if anyone has had this problem before but any help would be appreciated.
Old Feb 24, 2008 | 05:33 PM
nhill2090's Avatar
nhill2090
my truck just had a steering wheel vibration/slighty side to side shimmy (read: slight)...i figured it was my swampers getting out of round so i took them to get it balanced/aligned. ended up having a bad upper ball joint bushing on my drivers side causing the vibration. the part was only liked $20
Old Feb 24, 2008 | 07:19 PM
PowerStroker?'s Avatar
PowerStroker?
It could have something to do with how far into the brakedown lane you drive.
Old Feb 24, 2008 | 09:56 PM
white Buffalo's Avatar
white Buffalo
I had a similar problem, not sure it is the same for you since mine is 2wd. But my steering drag link bar was getting pretty loose where the Pitman arm would connect to the drag link. It started out as a slight shimmy from 45-55 mph and gradually got worse. The drag link seems to be a common issue. I also found out that I need to replace my ball joints soon.
bob03
Nov 2, 2005 06:35 PM
mowreyp
2004 - 2008 F150
Apr 17, 2005 04:02 AM
GLakes
2004 - 2008 F150
Jul 25, 2004 12:56 AM
DeckedoutF150
2004 - 2008 F150
Feb 24, 2004 12:16 AM
onsitewv
Oct 4, 2003 04:24 PM
