Temp gauge reading Cold
Old Jul 25, 2002 | 10:50 PM
blueoval79's Avatar
blueoval79
I put a new thermostat(195F), water pump, and replaced all the heater hoses. My question is my temp gauge is always reading Cold. When i replaced the thermostat housing I didn't install the vacuum switches because the part store didn't have any in stock, original ones were cracked. So i used the plugs that came with it to plug the holes on the housing. Could this be the problem and does anybody have a chart or diagram to where these vacuum lines hook up to? any help would be appreciated.
By the way, it's a 400 outta a 79 F250.
Old Jul 26, 2002 | 01:23 AM
Superdave's Avatar
Superdave
I assume you are using your factory temp gauge. To check your gauge itself, pull the single wire from the temp sending unit and ground it, using a makeshift wire, (I use a 2' piece of wire with aligator clips on each end, bend a paper clip or something similar, where it will fit in the wire end. Fasten one end of the wire to the paper clip then ground the other end to a good ground) then turn your ignition key to the on position, the gauge should peg. If it pegs, your temp sending unit is bad. If it does not peg its in the gauge or wiring.
Old Aug 1, 2002 | 01:29 AM
FordsForever460's Avatar
FordsForever460
Your temperature sending unit may have failed or if someone put in a
new one I hope they didn't use teflon tape. If you use tape on sending
units the unit won't ground to send the signal. Good luck. Andy.
Old Aug 1, 2002 | 01:48 AM
blu93gt's Avatar
blu93gt
Cbad285
Jan 30, 2016 10:06 AM
Jhow88
Nov 20, 2014 02:39 PM
GeorgeL
Jun 26, 2014 01:05 PM
vintshave
Nov 9, 2013 03:25 AM
mibson
1983 - 2012 Ranger & B-Series
Nov 25, 2009 05:11 AM
