ECT Sensor Quick Question
Old Feb 23, 2008 | 08:28 PM
floridasun1983's Avatar
floridasun1983
Since replacing the TPS on my dad's 85 F150 302 carb'd truck, its back running well, but one thing he and I both noticed, it seems to be stuck in "fast idle" that you expect during warm up. The motor doesn't idle down to normal speed once the engine is warmed up. I pulled codes on it from a KOER test and it came up with a code 21, which indicates the ECT is out of spec. My question is, could a faulty ECT sensor be tricking the computer into thinking the engine is perpetually cold, and thus be responsible for the fast idle? Thanks in advance.
Old Feb 23, 2008 | 10:13 PM
Franklin2's Avatar
Franklin2
It could be. But make sure the engine is warmed up before pulling the codes. If it's below 50 degrees, it will spit out a code from the temp sensor.
Also make sure your throttle blade is clean, and is set correctly. If it's open too wide, or the idle air control motor is gummed up, it can stick and cause a high idle.
Old Feb 23, 2008 | 10:41 PM
floridasun1983
Thanks. Engine was warm (had just returned from a 15 mile trip and with a bad fan clutch, it gets really warm, will be working on that in a few days). Nothing seems out of the ordinary, it idled fine before the TPS went haywire. The EGR system appears to be totally shot as well, but I'm working on one problem at a time.
Old Jun 21, 2008 | 09:39 PM
justintino233's Avatar
justintino233
Hello
I'm having a similar issue with a fuel injected 302 in a 1985 f-150. Did changing the ect solve the issue?
briankoon14
31
Nov 13, 2012 05:29 PM
muddydawg
Nov 4, 2009 04:01 PM
Pablo-UA
Aerostar
13
Jun 26, 2006 10:56 PM
matt f350
Jan 16, 2003 11:12 AM
KTMNealio
May 30, 2000 03:22 PM
