Aerostar Ford Aerostar
Engine stalls at idle when cold
Old Jun 18, 2006 | 11:44 AM
Pablo-UA's Avatar
Pablo-UA
Sometimes, when the engine is not warmed up (temp. less than 50 dgr C) it stalls on a run. Not, at idle, but when I drive and have to slow down, i release thrust pedal and put the shiftstik at N, it may stall. No codes. ISC is ok (i tried to disconnect it and to connect it directly to battery, engine revs!). Idle is too slow when the engine is not warmed up. ECT sensor is good! Voltage and resistance depend on temperature and it reads correctly (I've checked it with ECT resistance/signal level tabel). What to check?
Old Jun 21, 2006 | 01:25 PM
1975Ford's Avatar
1975Ford
Could it be the transmission? Torque converter not disengaging?
Old Jun 21, 2006 | 02:19 PM
96_4wdr's Avatar
96_4wdr
Pablo has a DIYer racing Aero with 5 sp manual Volga tranny
what is measured voltage to ISC IAC at cold idle and <50C idle?
may be partially plugged in area one can not see
does the '89 3L have an I.ntake A.ir T.emp sensor that feeds variable d.c. voltage to ECU based upon intake air temp?
VREF>SIG RTN on IAT should be 5v dc
sensor voltage needs to be >1.5v at 30d C air temp and >3.5v at 10d C air temps for increased cold weather fuel load
use ECT sensor graph for IAT voltages
because of placement and design of stock Aero intake box, there is some warming of intake air with warm/hot 95d C. engine which decreases fuel load/oxygen intake and power
i believe on Ford ECU programming for auto tranny Aero engines, they commanded the injectors totally off on closed throttle coast down until speed was below 5 mph to increase fuel mileage....you may have to find a manual tranny ECU that has different closed throttle coast down algorithm and an ECU clutch sensor
Old Jun 22, 2006 | 08:19 AM
Pablo-UA's Avatar
Pablo-UA
96-4WDR! I will check it today! But I have the other suggestion! May be TPS is not position correctly ore bad! Sometimes I have 1/2 sec pause after throutle pedal pressing before engine revs up! I have no codes!
Old Jun 22, 2006 | 08:56 AM
1975Ford's Avatar
1975Ford
Inspect and Check all vacuum hoses and lines.
Old Jun 22, 2006 | 09:03 AM
Pablo-UA's Avatar
Pablo-UA
They are OK! If hose is bad, my engine revs up!
Old Jun 22, 2006 | 03:36 PM
96_4wdr's Avatar
96_4wdr
0.5 sec throttle delay not good on freeway on ramp lane during rush hour....
TPS, brain dead cpu in ECU, or wet noodle throttle cable
my money is on the TPS
Old Jun 22, 2006 | 11:16 PM
lv2race's Avatar
lv2race
Thumbs up
Pablo, on a side note, GOOD LUCK IN THE WORLD CUP! We are out , so I hope you guys beat Tunisia and move on! I will be rootin for you!
Looks like you will get the Swiss or Korea. Both teams are good. I bet you get the Swiss. Good luck and go get 'em
Old Jun 23, 2006 | 09:08 AM
Pablo-UA's Avatar
Pablo-UA
96WDR! Why I have no CE light ore codes?
Iv! Tunisia won the lust game with Spane! But the Ukraine lost the game with Spanish team! So I'm not sure, but I belive our team is lucky!
Old Jun 23, 2006 | 09:26 AM
Bear River's Avatar
Bear River
Former ******
In our 1992 E-350, a bad TPS didn't set a code until it was so bad that the vehicle was barely drivable. At that point, it took up to thirty seconds to get to 30 mph. Don't be surprised if there s no code.
Old Jun 23, 2006 | 09:32 AM
Pablo-UA's Avatar
Pablo-UA
Thanks! I gonna check TP voltage!
Old Jun 23, 2006 | 12:02 PM
lv2race's Avatar
lv2race
Ukraine 1 Tunisia 0
Congrats!
Old Jun 23, 2006 | 12:14 PM
Pablo-UA's Avatar
Pablo-UA
Yeeess! Cool! Yes
Old Jun 26, 2006 | 10:56 PM
lv2race's Avatar
lv2race
Ukraine wins again!
Ukraine wins in PK's!
Bring on Italy!
Go Ukraine!
hippie21
1983 - 2012 Ranger & B-Series
Mar 9, 2011 06:01 PM
adamec
Aug 17, 2003 08:16 PM
Kevin
15
Apr 14, 2000 05:23 PM
