Sponsored by: Real Truck
HELP!!! keyless remote
Old Feb 23, 2008 | 07:11 PM
1eyedjack's Avatar
1eyedjack
Hello everyone
I need a litle help on programing my keyless entry. I tried and tried to program a new remote with what the owner's manal says but nothing happends. grrrrr
Anyone know a little trick on how to do such a thing?
Old Feb 24, 2008 | 08:37 AM
Maxium4x4's Avatar
Maxium4x4
What year?
Old Feb 24, 2008 | 08:40 AM
Maxium4x4's Avatar
Maxium4x4
NOTE: All remote transmitters and the wireless keyless entry keypad (F-Super Duty vehicles built before 12/03) must be programmed at the same time.
NOTE: Programming (or reprogramming) the remote transmitters or the wireless keyless entry keypad can be accomplished using a diagnostic tool or by carrying out the following steps:
  1. The vehicle must be electronically unlocked before entering program mode using the remote transmitter, keyless entry keypad (if equipped), wireless keyless entry keypad (if equipped) or door lock control switch while the driver door is open.
  1. Turn the key from OFF to RUN 8 times within 10 seconds, with the eighth turn ending in RUN. If the module has successfully entered program mode, it will lock and then unlock all doors.
  1. Within 20 seconds, press any button on a remote transmitter, or enter command on the wireless keyless entry keypad and the doors will lock and then unlock to confirm that each remote transmitter or wireless keyless entry keypad has been programmed. Repeat this step for each remote transmitter or wireless keyless entry keypad.
  1. If the door locks do not respond for any remote transmitter or wireless keyless entry keypad, wait several seconds and press the button again or enter another command on the wireless keyless entry keypad. If the door locks still fail to respond, refer to Inspection and Verification in this section. (Make sure that no more than a combination of 4 remote transmitters and wireless keyless entry keypads are attempted to be programmed.)
  1. Exiting the programming mode is accomplished if one of the following occurs:
    • The key transitions to the OFF position.
    • 20 seconds have passed since entering programming mode or since the last remote transmitter or wireless keyless entry keypad was programmed.
    • The maximum number of remote transmitters and wireless keyless entry keypads have been programmed.
Old Feb 24, 2008 | 06:57 PM
blong2107's Avatar
blong2107
ok i dont know my code on my dor keypad so how do i get this or program a new code of my own in?<TABLE class=tborder cellSpacing=1 cellPadding=4 width="100%" align=center border=0><TBODY><TR title="Post 5786192" vAlign=top><TD class=alt1 align=middle width=125>Maxium4x4</TD><TD class=alt2>NOTE: All remote transmitters and the wireless keyless entry keypad (F-Super Duty vehicles built before 12/03) must be programmed at the same time.
</TD></TR></TBODY></TABLE>
Old Feb 24, 2008 | 10:18 PM
1eyedjack's Avatar
1eyedjack
Thanks maxium it worked
Old Feb 24, 2008 | 10:31 PM
Budman1962's Avatar
Budman1962
Does anyone know if a remote from a 97 f150 will work on a 2000 f250?
Budman
Old Feb 25, 2008 | 06:55 PM
Maxium4x4's Avatar
Maxium4x4
Programming Personal Codes
A unique personal 5-digit code can be programmed by following these steps:
  1. Enter the factory set 5-digit code (the keyless entry keypad will illuminate when pressed).
  1. Press 1/2 within 5 seconds of Step 1.
  1. Enter the unique 5-digit code.
The personal code does not substitute for the permanent factory set code. Either code can be used to access the vehicle. In addition, if a second personal code is programmed, it will simply overwrite the previous personal code.
Old Feb 25, 2008 | 06:57 PM
Maxium4x4's Avatar
Maxium4x4
blong2107, This code is provided to the customer through a wallet card in the Owner Literature package. In addition, this code is available through a diagnostic tool and is also printed on the vehicle security module label. When entering codes each digit must be entered within 5 seconds of the previous button press.
Old Feb 26, 2008 | 12:10 AM
blong2107's Avatar
blong2107
thanks maximum, i bought the truck used from a guy he didn't give me the code i haven't ever thought bout it haha but it'd be nice to know... where is the security module label at?
Old Feb 26, 2008 | 07:48 AM
redford's Avatar
redford
FTE Leadership Emeritus
It will be on your security module, buried under a lot of wires under the dashboard. Removing the radio or the "panties" hook will usually allow you access to the code stocker.
Old May 9, 2008 | 11:17 AM
James Adams's Avatar
James Adams
keyless remote programming question ??
..........new to this forum, first post.
Seems that most of the keyless remotes are being taken at the car auctions before the cars are sold. Seems like a small industry of "selling remotes" and owner manuals has sprung up on ebay.
My 2005 F250 FX4 has two keys but no remotes. I've been reading all the posts but have a couple of questions.
Can I assume that an FX4 comes with remotes? Do I have to try and find if the option is installed?
I have no codes, (the card is missing).......can I still program two new remotes from Ford using the directions in the owners manual?
Unlike certain other cars, can old remotes be "reflashed"?
Porsche for example requires an original Porsche factory key (new, no previous programming) the car, and the diagnostic tool, to program a key.
thanks for any help.......James
Old May 9, 2008 | 02:14 PM
Beerstalker's Avatar
Beerstalker
Welcome to the site James.
FX4 is just an optional package, it doesn't tell us if you have keyless entry or not. If you have a Lariat, or if your truck has the keypad on the outside door then you do have keyless entry. If you have keyless entry all you need to do is follow the steps in post 4, no special tools or anything are needed.
Old May 9, 2008 | 03:09 PM
crazandy's Avatar
crazandy
Budman
It should I programed a remote from a 2003 focus svt, and a 92 ford probe remote on my 07 F350. Give it a try, worst thing that happens, is it wont' do it. Just be sure to un program it from the 97 f150, because if the 2 vehicles are near each other you will unlock/lock both of them.
Old May 9, 2008 | 03:35 PM
James Adams
thanks....
Thanks for the help. Need to figure out if this truck had keyless entry from factory.
Old May 12, 2008 | 01:28 PM
Beerstalker
An 05 with keyless entry will have the keypad on the door. If you don't have the keypad, you dont' have keyless entry.
