Pls Help! Need sleeper Perf. upgrade advice.
This part I'm sure you can relate to. These guys at the local shows or cruise's will get out and run up and down the main strips. This is the part I avoid. The mopar, GM, and some of the ford guys, always egg me on to get out there and run the big engine for them. This is when I tell them the wife is calling me to go home. Even with the 400 well tuned the best I can do is sling a little gravel getting out on the road to leave.
Please keep in mind that I've got to keep a stock look. Stock manifolds (at least the exhaust manifolds), valve covers, ignition, etc. I know I may have to give in for the intake. I even thought of grinding down the brand name on the intake manifold and painting it Ford blue to try to fake out judges if I have to go 4bbl. A cam and timing chain/gear set-up is a definite because it's internal and hidden.
Here's my question. I have decent mechanical ability, all the hand tools I think I need, a little bit of hobby money, a small garage, and all of the upcoming winter to try to fix the (my, our) problem. I was wondering what any of you would do to keep this engine compartment as stock looking as possible, relatively smooth idling, and able to at least perform as well as other stock engines with the same displacement. Upgrades probably need to be limited to bolt-on's. I love this thing and don't want the 351M/400 class engines to get a reputation around here as a smog slug to avoid. Any advice from you knowledgeable folks is appreciated and will be taken seriously. Thanks in advance for any response.
The performer cam makes decent power and idles like a stocker. At first all I changed was the cam, intake and carb. It made a big difference.
Later I added dual exhaust with flow master mufflers. The 3 chamber mufflers sounded great but a little loud. I didn't need cats because it was a '73 vehicle.
The only other thing I wanted to try was a little more compression.
Are you familiar with this build up?
http://home.earthlink.net/~tcrocker/400.html
>and 39k well cared for miles. The vehicle is all stock,
>correct, and detailed down to the hose clamps, decals, etc.
>intake.
>I was wondering what any of you would do to keep this engine >compartment as stock looking as possible, relatively smooth idling, >and able to at least perform as well as other stock engines with the >same displacement. Upgrades probably need to be limited to
>for any response.
Well since you need to keep a "stock" appearance, I would say Aussie 302 2v heads are it, you will be able to keep your stock exhaust manifolds. Dynagead flat top pistons, a new cam. Now for intakes, you can get a stock 351c 2v one and use weiand spacers, and aftermarket 400 one and grind it down (the name) or you can spend lots of money doing what dave williams did to a stock 400 intake.
http://www.angelfire.com/ar/dw42/index.htm
its the link to kenny moores 434 sroker. what dave did was mill out he 2v stock to a 4v stock. Dave says the stock intake is better than the aftermarket ones. the link has exceeded bandwith or else i would have posted that.
with the right cam and engine planning you should be well over 350hp and probably into the 425+ range. then you can go be respectable.
Thanks again!
as for the carb - i dunno. i assume you want a motorcraft? they probably come in as many sizes and configurations as holley's. with factory exhaust manifolds, anything from a 600 to a 750 depending on what else you do to it.
if you're looking at aussie heads, look carefully at the area around the exhaust ports - seems like i noticed something different about them, but maybe more subtle than an aluminum intake!
in some cases, stock exhaust manifolds can be ported - some are thicker and more constricted than others. i did a pair using a drill and several grinding stones - i now use a high-speed die grinder with carbide carbide burrs for that kind of thing... much better! then smoothe it out with stones. wear eye protection!!! also, 4v exhaust manifolds might be useful.
the heads, intake, and exhaust manifolds can be gasket matched and touched up, with a lot of work around the valve guides and under the seats. i've read that a performance valve job can make a big difference too. i saw some flow data that showed an improvement of about 5% from using fancy "race" valves with undercut stems. even more improvement from going to larger valves. this might decrease low-rpm torque somewhat, but if you're drag racing, then the power on the top end is more what you're interested in.
2 BIG things - STALL and GEARS. neither one can be seen once installed. they make heavy things MOVE! also, add posi if it's not in there already
as for the cam - that depends on the rest of it. if you get an aftermarket intake, a fairly big carb, higher compression pistons or aussie heads, gasket match, port the heads, oversize racing valves, 3200 stall, 4.33 or so gears, shift kit... then a bigger, higher-revving cam would work. if you take a more mild approach, then a low/mid range torque cam would be better. it just depends on how far you want to take it. the only visible parts are the intake and exhaust manifolds. you can't go TOO wild without headers, but you should be able to get a huge difference compared stock.
what kind of car is it in? weight makes a difference in the setup, but i assume that any car with a 400 in it is HEAVY...
you can do all this without removing the engine block. on a 40K mile motor, you might have a slight ridge to shave off to get the pistons out, then a drill-powered hone and stock bore pistons. it CAN be done that way, but keeping the short-block as-is (except cam & timing set) and using the aussie's would be much easier.
here it is: http://members.tripod.com/lyc_42/km434/km434.htm
>option for the 400, but that it was so rare that nobody has
>ever actually seen one.
yes ford had a part num, it was a dealer installed item. they were always out of stock. i think we have a better shot at seeing the lock ness monster than seeing one of these.
on a side note, i did see a holley street dominator for the 400 at the nov swap meet at daytona.
i seriously like the modified stock 2v intake though, for something like this. just port the heck out of it, put a motorcraft carb on top, and throw a K&N filter in the stock housing - 100% stock ford parts, and more kick than any stock 400 ever had!
