Is this the multi-function switch on the steering column on X 97 to 01? I tried to get one in UK but was told by a Ford dealer that "they are no longer available from Ford". He said they used to stock them for £84 but no more. How are you supposed to get spares for a 7 year old Ford?
I just looked them up at the Y2K parts site. They are listed under "
Collision Catalog Steering column , Shroud switches and levers ,Combo switch ,Signal and wiper". WOW - $103.17!
I replaced one in my sisters 95' several months ago. The switch was around $110 from the stealership. My 04' SD uses the same multi purpose switch as her explorer does. It is a common part and they are still made.
I don't know the part #. The stealership looked up the part #.
Thanks for the help....I Should have been more clear. I know someone who has one of these, and if I had the Ford Part Number I would know if it is the correct part.
