1997 explorer - Multi-function part number
Old Feb 23, 2008 | 12:38 PM
tcatt's Avatar
tcatt
Can someone give the ford OEM part number for this part?
Thanks,
Old Feb 24, 2008 | 07:24 AM
ukexplorer's Avatar
ukexplorer
Is this the multi-function switch on the steering column on X 97 to 01? I tried to get one in UK but was told by a Ford dealer that "they are no longer available from Ford". He said they used to stock them for £84 but no more. How are you supposed to get spares for a 7 year old Ford?
Old Feb 24, 2008 | 10:29 AM
ccecilm2's Avatar
ccecilm2
I just looked them up at the Y2K parts site. They are listed under "
Collision Catalog Steering column , Shroud switches and levers ,Combo switch ,Signal and wiper". WOW - $103.17!
Old Feb 24, 2008 | 11:12 AM
caseys's Avatar
caseys
I just looked at Rockauto and it looks like they have what you want for $59... they have a Motorcraft listed with a part number to compare.
Old Feb 24, 2008 | 04:34 PM
dkf's Avatar
dkf
I replaced one in my sisters 95' several months ago. The switch was around $110 from the stealership. My 04' SD uses the same multi purpose switch as her explorer does. It is a common part and they are still made.
I don't know the part #. The stealership looked up the part #.
Old Feb 26, 2008 | 08:09 PM
RockAuto Faly's Avatar
RockAuto Faly
Turn Signal Switch
Thanks,
Hi,
Like the other guy said, we have that part in our catalog.
Here is the link.
http://www.rockauto.com/catalog/rafr...&parttype=4832
make sure to take a close look at the pictures. Most of them for this part are fairly accurate.
If you got questions, let me know.
Thanks,
Faly
Old Feb 26, 2008 | 09:00 PM
tcatt's Avatar
tcatt
Thanks for the help....I Should have been more clear. I know someone who has one of these, and if I had the Ford Part Number I would know if it is the correct part.
