Cat Back?
Old Feb 23, 2008 | 10:50 AM
goneinsixty's Avatar
goneinsixty
Cat Back?
Does 4" cat back exhaust really make that much of a difference? It seems that the exhaust is only capable of flowing as good as the smallest exhaust (stock down pipe and cat) component will let it.
Old Feb 23, 2008 | 11:20 AM
07psdrookie's Avatar
07psdrookie
As long as you delete your cat!
Old Feb 23, 2008 | 11:48 AM
bruno6491's Avatar
bruno6491
A cat back does make a difference in performance and lessens the spool up time of the turbo
Deleting the cat makes a big difference in power as well as sound and decreases time to spool up the turbo
Bruno
Old Feb 23, 2008 | 12:35 PM
Green_Monster's Avatar
Green_Monster
I gutted my cat yeah I wont have it at emissions time but it looks on the up and up from under the truck. Besides mass doesn't throw diesels on the dyno
Old Feb 23, 2008 | 01:12 PM
hangon2me's Avatar
hangon2me
Do a 4" Turbo back Exhaust system. If you only do a Cat back you will not see any big increase performance and MPG's. By removing the Cat I have noticed that my other truck had lower MPG's and slower Turbo spooling.
Old Feb 23, 2008 | 01:32 PM
cartmanea's Avatar
cartmanea
Am I reading this wrong, or are you saying removing the Cat lowered MPG's and increased spool time? This seems backwards.
Old Feb 23, 2008 | 01:48 PM
bruno6491's Avatar
bruno6491
I got increases in the MPG as well as i lowered the spool up time of the turbo, interesting how your results are backwards
The turbo back is more work and unless you do towing or run the truck at WOT all the time, its not neccesary to do it
Bruno
Old Feb 23, 2008 | 02:29 PM
cartmanea's Avatar
cartmanea
I'm at WOT quite often
Old Feb 23, 2008 | 03:15 PM
Green_Monster
huh?
sorry hang, but those figures may be true for you but the majority of us would disagree. SInce I am not running a tuner and have a straight out exhaust leaving my stock downpipe is reducing my numbers by a negligible amount ( besides its to friggin cold up here to spend the extra 30-45 min messing with it ) The 4" downpipe will cause fit problems and give you a fit as well.
Gonein60 if you decide to go turbo back get a 3.5" DP and delete the cat but save the cat if you are concerned about the emissions monster. And remember MPG's are directly proportional to the weight of your right foot
I will be doing about 350 miles tomorrow and possibly towing a trailer thru the mountains of VT I will definitely get back to ya'll on the performance.
Old Feb 23, 2008 | 06:20 PM
hangon2me's Avatar
hangon2me
My 4" Turbo down pipe was no problem to install. You really need to remove the stock Turbo-up pipe , get rid of the restrictions and install the EGR delete plate . I now have no Turbo Lag and my MPG's are in the 17's, before 14's or less. Max EGT's are 1200 pulling a 10,000 trailer in the summer. On my old 2004 6.0L with the Cat removed I had major Turbo Lag and the MPG's were 12's after the Cat was removed. The Cat has almost no restriction in it going 4" in and 4" out. I have no tuner and I need to keep mine in because I get Smog checked every year.
Old Feb 23, 2008 | 08:16 PM
goneinsixty
Has anyone else had the same experience with the cat delete causing major turbo lag and poor mpg. I have an '03 and get 13.5 to 14 mpg and sure don't want to do something that will make it even worse.
Old Feb 23, 2008 | 08:22 PM
Wilber15's Avatar
Wilber15
Duals aren't going to increase turbo spool up time. The turbo is VGT operated and is already at max duty cycle(around 65%) when at idle or light cruise. Back pressure is measured in the exhaust system pre turbo also(so duals have no effect). They will give you good sound though....
Old Feb 23, 2008 | 08:40 PM
cartmanea's Avatar
cartmanea
Reducing restrictions after the turbo will make it perform more efficiently and reduce spool time. There is no way for it to affect it differently. This is from a fluid dynamics standpoint, so unless we are wrong about the basics of physics...
Old Feb 23, 2008 | 08:56 PM
Storm's Avatar
Storm
Diesels are generally a 0 BP operation.. Cat addition is the work of the EPA (rejects).. Removing the CAT provides less spool time, less back pressure and slight increase in pressure.. If the MPG drop, its due to the driver and his foot.. There is no "Negative" advantage with a Turbo Back Straight.. That is why "technically" diesels are authorized for Inspections in some states with Straight systems and do not require an emission test. Here in Texas you can walk up and tell an Inspector "I have a straight exhaust, no cat or muffler".. He won't say a thing and you'll still pass.
The effectiveness of the exhaust also plays a vital role in lowering the EGT's. It's more ratio'd towards effectively lowering EGT by increase volume for air and reducing resistance (back pressure). You can see upwards of 200-400* in temperature drop with moving to a free flowing 4" systems versus a stock system.
Old Feb 24, 2008 | 06:53 AM
Green_Monster
Gonein60
My mpg's went almost 2 miles per gallon in the first tank after exhaust and cat delete.
Listen to the the Green Beret he explains it right on the money, if it has a negative effect either its your driving your math or something else but not the exhaust and cat delete. Its kinda like saying rain pours up to the clouds not down, it could only happen in bizzaro world
my $.02 ..... I might need change
