Wicked Wheel Install Questions???
Old Feb 23, 2008 | 03:55 PM
Planeoldguy's Avatar
Planeoldguy
I'd replace the donuts, FelPro p/n 8194 work great, They are slightly bigger than stock and squish down nicely, Just use lots of antisieze on em.
They were 7.14 for the pair at NAPA.
Old Feb 23, 2008 | 04:58 PM
Layson's Avatar
Layson
Originally Posted by nissandoc
gettin' ready to do mine also. two ?'s. should i replace the up pipe doughnuts as well? and were to buy(best place)the wheel from? i ordered the o-rings from itp but they didnt have the wheel. also ordered the fuel cross connect kit from dino fuel alt. gonna do it all at thw same time and dont want to miss anything.
Is there soot behind the turbo on the firewall?? If there are no leaks then there is really no reason to change it out... It is a little more work than just doing the wheel....
If you do plan on doing that then the turbo will have to be taken out for the up pipes and most likely for the fuel system...
You can get the wheel from www.dieselsite.com or just watch the classified sections... they are all the same and shouldn't be over 75 bucks...
4DConsumer
Dec 14, 2016 03:16 AM
664x4drvr
16
Nov 4, 2009 10:08 AM
superspike
29
May 8, 2004 03:27 AM
old farmer
Oil & Lubrication
Apr 9, 2004 12:57 AM
Mike W
Dec 27, 2003 12:15 PM
