heater blower motor
Old Feb 23, 2008 | 08:47 AM
fdude64's Avatar
fdude64
heater blower motor
do i have to remove the whole assy under the dash to replace the blower motor on a 79 f250 with out ac?
Old Feb 23, 2008 | 10:19 AM
masterbeavis's Avatar
masterbeavis
It helps to take the dash out. I think you can get it out without doing that.
See sig for more info.
Old Feb 23, 2008 | 10:23 AM
fdude64's Avatar
fdude64
yea i have replaced heater cores but never blower motors. it looked like i could take off the vent flip door and get to it but now it looks like i will have to remove the whole plennium
Old Feb 23, 2008 | 11:23 AM
tuckerjw's Avatar
tuckerjw
Yes you do. I had to do this a few months ago. It's really not that hard. There are nuts in the engine compartment that you will need to remove. Remove the passenger side vent, cables, and so on. It is a good chance to clean out the whole assembly. It will drop below the dash although it takes some wrangling to get it free. Also a good time to lube the cables and the 2 trap doors in the assembly. For me it was helpful to remove the cardboard glove box insert. That way you can get to the screws that hold the passenger side vent on. When removing the heater hoses remember that they are attached to some very soft metal of the heater core. It's very easy to bend or break it. If your heat is hot, don't worry about the core. It has foam around it from the factory that is hard to replace.
Suffice to say I know this part of your truck well. I have a 79 250 as well.
Let me know if you have any more questions
Old Feb 23, 2008 | 02:01 PM
OldMetal's Avatar
OldMetal
It helps to take out the glove box as well.
Old Feb 23, 2008 | 03:41 PM
fdude64's Avatar
fdude64
well the new motor and fan cage is in the heater box now just have to get it back under the dash
Old Feb 23, 2008 | 06:13 PM
fdude64's Avatar
fdude64
well the box is back in and the hoses are hooked back up, just need to hook up the wires to the motor. that will be tomorrow morning
