Pablo, if you have a handhelp propane bottle (plumbing burner), connect a section of rubber hose to the pipe after the valve, turn on the propane flow (slow) and aim the open end of hose at the potential leaking area, if there is a vacuam leak the RPM will increase.
Use in well ventilated area.
Of course a smoke generator can be used instead, but more investment($$$)
Ouh, with engines with MAP sensors ore Boost pressure sensors I had no problems related with MAF. Newer heavy trucks have MAF sensors.... to many problem... Just an example, MAF reads less air flow, EDC decrease power.... Well, but MAF works a bit faster.
