Frame widths 67 vs 78
Old Feb 22, 2008 | 08:07 PM
Redneck-Cowboy's Avatar
Redneck-Cowboy
I'd measure this myself, but I don't have the 78 yet and this will decide on me buying it, maybe.... Is the frame on a 78 or a hi-boy (earlier one) the same width as a 67 F-250? If so, how close are the body mounts? I have a 2wd 67 w/ a good body and a possiable 78 F-250 that's a rust bucket, so... is it close or am I gonna have to fab some mounts? I think I heard up to 77.5 were narrower then the later trucks and if so was the 67 the same width as the 77.5 and below? Thanks guys.
Old Feb 22, 2008 | 08:30 PM
f600nightmare's Avatar
f600nightmare
dont know if this will help but i had a 72 body on a 74 350 4x4 frame.
Old Feb 22, 2008 | 09:24 PM
wedefyu's Avatar
wedefyu
I've got a 67 2wd, and a 72 2wd, when I got the 72 it had no rearend but the guy said it used to be a 9er, just out of curiosity I measured my 79 F-150 spring pad distance, and the spring difference on the 72, and they were way different, like 4 inches, I can only assume that means the frames are different.
Old Feb 22, 2008 | 09:30 PM
fdude64's Avatar
fdude64
the 77.5 and earlier not sure how far had a frame that narrowed just behind the cab
Old Feb 22, 2008 | 09:41 PM
Redneck-Cowboy
Well I want to put this 67 body on a hi-boy frame, it has a divorced transfer case and all, but I was pretty sure there was no more highboy in 78, then ppl say the frame changed after 77.5, so I'm a little confused as to what I'm getting unless the cab was swapped onto this truck years and years ago, b/c the vin is a 78, plus it has a 400 in it, which also would make it a later drivetrain.
Old Feb 22, 2008 | 09:48 PM
fdude64's Avatar
fdude64
wll mine is titled as a76 but there is a sticker under the hood that says 79
Old Feb 22, 2008 | 10:06 PM
wedefyu's Avatar
wedefyu
I'm jealous fdude.What kinda mods on that beast?
Old Feb 22, 2008 | 10:07 PM
1969F2504X4's Avatar
1969F2504X4
I'm pretty sure you need an early 77 or older frame for this swap. It's been about 10 yrs since I did mine so I'm not 100% sure. Mine is a 69 body on an early 77 frame. Cab bolted right on but had to fudge the bed forward an inch and drill new holes for it to look right.
Old Feb 22, 2008 | 10:09 PM
wedefyu's Avatar
wedefyu
There was a high boy in 78 I think, I've got a friend with a 78 with a 460, it's also the divorced case, I think but I'm not positive, that on the build date it's just a late mid 77 truck titled as a 78. If you've got the skills to fab up mounts if they're wrong, and the truck is cheap, do it.
Old Feb 22, 2008 | 10:11 PM
Redneck-Cowboy
Well I'm mostly worried about the cab bolting on to tell you the truth, I'm not real worried about the box since it'll never haul anything (I can fab that on), just has to "be" there (this is gonna be a pulling truck). So am I correct in my thinking that there is no such thing as a 78 highboy and this is most likely a 77.5 and below frame?
Old Feb 22, 2008 | 10:15 PM
wedefyu's Avatar
wedefyu
Probably time for ya to bust out the tape measure.
Old Feb 22, 2008 | 10:25 PM
Redneck-Cowboy
Lol, I know, I gotta go find that "supposable" 78 first and my luck it will be all muddy or something underneath it.
Old Feb 22, 2008 | 10:28 PM
wedefyu's Avatar
wedefyu
Just out of curiosity, fdude, do you really like your 300 I6? I noticed you have a little bit of mods done to it, and wondered if you know about Clifford Performance. They Have everything you need to make a 300 blow peoples minds.
Old Feb 22, 2008 | 10:33 PM
Redneck-Cowboy
Were you talkin to me or does fdude have a modded 300 to?
Old Feb 22, 2008 | 10:36 PM
150ford's Avatar
150ford
Yup no more highboy in78. Mid 77 is was when the change was made to lower trucks/ friend off mine has a 77. One off the last highboys made. still uses this truck everyday. It would be just perfect for what your lookin for. It has a 460 in it too. He bought the truck new. Still looks nice. I dont think he would part with it though.. North off me in Ford counttry. There are alot off those old 78s around. Amazingly some are in [pretty descent shape. good luck on your truck build. Give the Wahoo guys a run for there money.
