1979 351M LOST SPARK
Old Aug 15, 2002 | 12:20 AM
boone6978's Avatar
boone6978
i lost spark! started fine the other day no problems, shut it off now it wont run. tried a couple different coils, my modualator got hot, back of it started melting,tried different ones, what could cause this? it seems to want to start when i turn the key back to the off position, im stumped. any help is appreciated. Thanks, Dan
Old Aug 16, 2002 | 03:29 PM
Torque1st's Avatar
Torque1st
Posting Legend
If your module got hot enough to melt it there may have been a short. Check the red wire AT THE MODULE to see if you have power when the ignition is ON. You may have burned up a wire with the short. You can also check this by jumpering the red and white wires at the module to Bat+. If the engine starts when you crank it you will have to remove the jumper to shut it down. Repair the wire when you find the bad circuit.
Old Aug 27, 2002 | 01:05 AM
boone6978's Avatar
boone6978
i figured it out, stator went out in distributor. Thanks for the help though. got a 400 that is going in soon, bye bye to stock ignition, MSD all the way. Dan
Old Aug 27, 2002 | 04:03 PM
beartracks's Avatar
beartracks
ford-power-f250
May 15, 2015 05:32 PM
Foryota
Nov 14, 2012 03:31 PM
fyre82
N. California Chapter
Sep 18, 2012 11:15 AM
STONER Dan
Aug 12, 2012 10:28 AM
RC Dan
Nov 7, 2005 04:49 PM
