Fpr Shim Question
Old Feb 22, 2008 | 03:44 PM
fmco_muddin's Avatar
fmco_muddin
Fpr Shim Question
I've read about the fpr shim and want to do ot but wanted to know how do you know if its a california model?
Old Feb 22, 2008 | 04:03 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Look on top of your fuel pump (in the engine valley) and if there is a big disk on top of the rear of the pump it's a cali model. On the fed. model you will see just the banjo bolt and two steel lines on the rear of the fuel pump.
Old Feb 22, 2008 | 04:09 PM
fmco_muddin
ok thanks i knew i read about it earlier but couldnt find it in past threads! Should i gauge it before doing the mod ? if so what size of fitting is it?
