351 M or 400
Old 08-25-2002, 09:26 PM
Sunfire_Stomper's Avatar
Sunfire_Stomper
Sunfire_Stomper is offline
351 M or 400
how do i tell if a engine is a 400 or a 351?
Old 08-25-2002, 10:59 PM
GT40man's Avatar
GT40man
GT40man is offline
351 M or 400
the crankshaft number
Old 08-25-2002, 11:00 PM
Sunfire_Stomper
351 M or 400
you cant tell just by looking at it
Old 08-25-2002, 11:15 PM
GT40man's Avatar
GT40man
GT40man is offline
351 M or 400
no, they are the same except for pistons, crankshaft and balancer. well the balancer is thinner on a 351m. i think its like 1.5-2.5 inches on the 400. the only real way is the engine code if you know its the stock engine or the part num on the crankshaft.
if you have a 351m and want to stroke it out to a 400, just change the 3 parts and bang, its a 400.
Old 09-03-2002, 12:55 PM
Noxious's Avatar
Noxious
Noxious is offline
351 M or 400
Old 09-03-2002, 12:57 PM
Noxious's Avatar
Noxious
Noxious is offline
351 M or 400
i always just grabbed a pistons and measured the stroke 400=4''
351=3.5''
Old 09-03-2002, 04:05 PM
garypettengill's Avatar
garypettengill
garypettengill is offline
351 M or 400
Get help! Have someone turn the engine over hand with a socket on the crank while you use a lo---ng screwdriver and measure the distance the piston goes down from TDC. 3.5" = 351 4.0" = 400.
Old 09-04-2002, 01:35 AM
blu93gt's Avatar
blu93gt
blu93gt is offline
351 M or 400
[updated:LAST EDITED ON 04-Sep-02 AT 02:35 AM (EST)]if it's all stock and it will spin the tires, then it's a 400...
Old 09-04-2002, 07:03 AM
bbtkd's Avatar
bbtkd
bbtkd is offline
351 M or 400
The VIN number should be stamped on the back of the block, I believe above the starter. The fifth position in the VIN should be a letter that corresponds to the engine. I don't have the late 1970's codes, but an "S" is likely a 400. An "H" is likely a 351, but you can't tell whether it was a 351M or 351W since they used that code for both. I presume you are talking 1975 or later.
If you cannot find the VIN on the block, and you believe the engine is original, then go by the VIN on the vehicle. Also keep in mind that even if the VIN on an engine indicates 351M, someone could have "upgraded" it to a 400...
BORDERBUM
02-10-2011 03:45 AM
RangerHaywood
15
07-05-2010 10:14 PM
cruz76
03-26-2006 05:40 PM
theonlybull
01-13-2003 08:04 PM
Nathan
13
04-18-2001 02:10 AM
Quick Reply: 351 M or 400
