Aerostar Ford Aerostar
injector resistor
Old Feb 22, 2008 | 10:47 AM
bertha66's Avatar
bertha66
injector resistor
Does anyone know where the injector resistor is, or have a picture of it. My 90 Areo with a 4.0 engine is still having issues, random CEL with no codes. I have run almost all the test that I down loaded from here and chenged the battery, alt. crank sensor, TPS, HCS, IBS, spark plugs and wires and coil pack. The HCS helped and the crank sensor helped, going down the road she runs fine, CEL will come on after driving 15-16 miles, but does not effect the way it runs. The one problem that contiues is when pulling away from a idle she wants to die and not start untill you hold the gas all the way open and it will sputter and then smooth out. Had a machanic friend say that it maybe the resistor for the injectors is going bad. Any thoughts about this? Thanks
Old Feb 22, 2008 | 11:19 AM
Pablo-UA's Avatar
Pablo-UA
Random CEL with no codes usually apeares when you have power supply prolem. When ECU power relay unterrupts CEL blinks for 2 seconds and no codes...
injector resistors are insude ecu...
Old Feb 22, 2008 | 01:35 PM
96_4wdr's Avatar
96_4wdr
i would start with cleaning the socket contacts and replacing the ECU relay
RY71
http://info.rockauto.com/SMP/SMPDetail3.html?RY71.html
only a $12 part at rockauto
but I don't think that is your problem
dying on warm driveaway and warm hard starting are signs of too rich an air/fuel mix. my guess=leaking injectors, especially if those are the 17 year old originals and have not been removed and professionally ultrasonically tank cleaned.
having to hold the gas pedal to the floor is a sign of far too rich a warm start mix. max TPS input tells ECU to shut off all FI activity until the engine starts and clears out extra fuel.
also test fuel pressure at the rail for max and min. pressure.
is there fuel in the FPR vacuum line?
Old Feb 22, 2008 | 02:12 PM
copper_90680's Avatar
copper_90680
My vote is with either the MAF or the IAC.
What are the HCS and the IBS?
Old Feb 22, 2008 | 02:41 PM
Pablo-UA's Avatar
Pablo-UA
No, it is power supply problem, I'm nearly sure. Try to run wire from + term. of Battery directly to ECU to be sure. And not to ECU onlu but to + terminal of coil.
Before you replace expencive parts do the cheap staff first.
Old Feb 22, 2008 | 06:52 PM
bertha66's Avatar
bertha66
HCS heat control senser and IBS, sorry ment IAC and I did change the MAF
Old Feb 22, 2008 | 06:55 PM
bertha66's Avatar
bertha66
RY71
The injectors have been replaced, but that was 90k ago. I will be testing the feul pressure tomorrow.
Old Feb 23, 2008 | 02:56 AM
96_4wdr's Avatar
96_4wdr
bertha,
you must love that old girl, you've put some parts store bucks into her
hope you find the problem soon.
mine is starting to show her age. think towing days are about over
looking at a Dodge 1 ton Cummins diesel
Old Feb 25, 2008 | 11:37 AM
bertha66's Avatar
bertha66
bertha,
It's my wifes love, and if she's not happy, I'm not going to be happy. Most of the parts came from the other Areo that she got when her father died 3 years ago, so did not spend alot. I did find out that the parts house gave me a bad HCT, so I switched it out again and checked the fuel pressure, 34lbs, and ran her to the next town, 20 miles and she ran great, but the CEL came on at 19 miles out. Did the same on the return trip home, ran great, CEL came on a mile from home.
Old Feb 25, 2008 | 02:16 PM
Pablo-UA's Avatar
Pablo-UA
well, check ECM power supply againe. CEL w/o codes, jercking is usual issue when ECM power supply interrupts on a run.
Old Feb 26, 2008 | 10:11 AM
rebocardo's Avatar
rebocardo
Check the coil pack. I know it is a hassle to get to on a 4.0L Aerostar and you have to remove it to test and inspect the potting , but, I think that might be the problem if it is not throwing codes and it appears to be a power supply problem.
Old Feb 26, 2008 | 10:51 AM
bertha66's Avatar
bertha66
I did switch the coil pack with my other Aero, with no change in what she is doing. Thanks
Old Feb 26, 2008 | 03:51 PM
copper_90680
Allen,
Looking back through the thread, I realize that few of us answered your original question about the whereabout of the injector resistors. As far as I know, the injectors do not have a resistor per se. Whatever resistance you read across the terminals is the resistance of the coil winding. My guess is that you should measure them all with an ohmeter, in both directions since there might be an internal diode. If the resistances are about the same for all six injectors, I'd say you are OK. Then, all you have to worry about is whether they are plugged up or leaking.
Old Feb 26, 2008 | 04:29 PM
bertha66's Avatar
bertha66
Yes, the original question was answered, and I thank you. All the rest has been Very helpfull, The random CEL has been driving me very crazy and it's not much of a drive, so thanks to all and I will let you know if I find it.
Old Feb 26, 2008 | 05:07 PM
96_4wdr's Avatar
96_4wdr
no internal inductive kickback protection diode in the Ford injectors.
all the protection is done on the output of the injector FETs in the ECU/PCM
the CEL will pulse on/off with each detection of a cyl miss.
the cyl miss algorithm requires a certain preset # of misses in a preset time period to turn the CEL on permanently and set a miss code.
cyl. miss is detected by the position timing of crank sensor, camshaft sensor and ign PIP sensing which is determinded by engine model and year. OBDI or II and distributor or EDIS
OBDII EDIS will pinpoint one particular cylinder missing and giving problems with unique cyl # CEL set and real time scanner monitoring
