400 stroker. What again?
The application is the 351C using the 302C rods. I finally got the specs after convincing KB tech that it was theirs.
"That is our number, the3434H.That piston is for a stroke of 3.500, comp. height of 1.415, 4.00 bore std.,ring pack of 2-5/64 1-3/16. The pin dia. is .9122, rod length 6.025 and piston weight is 489, and pin 103g. The cc to head volumes are as follows for comp. ratios, 62cc-11.1,66cc-10.6,76-9.5. I hope this what you were looking for.
Thanks Tech Dept."
It's a flat top "claimer series" piston. $375 AU (about $207 US).
Take a 400 crank and off set grind the journals to a 4.17" stroke with the 2.123" 240 I-6 rod journal. The 240 rod is 6.795 long, 912" pin. Rods are $80 a set. They have to be narrowed.
10.297
-2.085 (half stroke)
-6.795 rod
-1.415 piston
=0.002 deck
http://www.kb-silvolite.com/calc.phtml
I came out with about 10.8:1 with a 76cc chamber. There are many ways to change the numbers. The 4.17" stroke can be reduced. The 240 rods can be shortened slightly with bronze bushings or resizing the big end.
The KB pistons can be shortened slightly or a dish added on a lathe. I used .041 for the head gasket thickness, but I think up to .060 is available. Polishing the combustion chamber will add about 3cc.
There has been a lot of talk about the benefits of using quench heads to fight detonation, but on a stroker motor this size, a very large piston dish matching the combustion chamber shape is the only way to make it work correctly.
I think the quench benefits on a street motor have been overrated. The only thing that should be avoided is a domed piston with an open chamber.
A note from the Australian Mail order company said, "We Ship all around the World, Internaional order can take our Australian GST
(10%) off the prices listed.
thankyou
VPW Sales"
Even better. Pistons would be $341 AU ($188 US) and their 3V Aluminum heads would be $2545 AU ($1400 US)
http://www.vpwmailorder.com/ieframeset.html
>aussie heads? Thanks a bunch fellas!
this is not for a "regular" 400 - this is for a stroker motor with a custom offset-ground (stroked) crank, and 240 I6 rods.
the pistons i got to use would raise the comp to high anyhow. be good for the race motor i was thinking about though. this stroker option is getting cheaper all the time.
later.......:P
There aren't many stock rods longer than the 400. An aftermarket 6.8" rod set is less than $400, but the 2.2" journal was too big. I couldn't off set grind a stock 400 crank to the 4.17" stroke I wanted. Custom long rods with a 2.1" journal were $800 and up.
The 240 I-6 rods were long enough, cheap ($80), and they use a .912 pin like the stock 351C. The KB 3434H is the only short piston I found with a .912 pin. I lucked out. I like the price too ($188).
If you want a race motor, quench heads will get you 13:1 compression with the KB flat tops. I think a 426 would be great with 4V heads.
351C open chamber or 400 heads would be 10.5+:1. I think there is enough piston thickness to allow for machining a shallow dish to get the compression down to 9.5:1. It's very easy to do on a lathe.
My mission is over. It's time to collect the parts and put it together.
-Jim
so um brian, can it take enought lathing to get the cr from 13:1 to say 11.7 with closed heads?
i am a stinker.....
This may be my ignorence speaking here but how do these 'flat-tops' yeild such a high compresion. I thought flat tops on a 400 were only good for about 9.0:1. I see these pistons have close to zero-deck though as compared to the excessive deck clearence the stockers have so is that the difference, over a point and half compression just by zero-decking? Or I am probably missing something
