what to do for lower back ache
But, I am in good shape. I hike, I shoot, I walk. I am active.
This last Thanksgiving, I woke up and could not get out of bed. My back was in total stress. After five days my doc subcsribed me drugs, that did not work. I finally got up and walked. It hurt like hell! I walked more the next day. In a few days I walked up a hill. I kept walking.
Do not stop. You have to get over the pain, and go on. If you don't, the outcome will be bad!
i'm not shooting anyone down, but drugs mask symptoms. they never heal them.
let's just say..been there, done this!
Helps to know if your pain is muscular or nerve related...the former is more constant pain while the latter is usually abrupt sharp pain. Never went the chiropractor route because of wife's bad experiences. I'd talk to a physical therapist about a custom tailored exercise routine...go slow at first but stay with it...keep moving as much as you can. Pulling your knees to your chest is always a good one.
Once stabilized you might consider yoga but some of those moves can put you right back in traction! Hang in there!
you can put the vicoden right in the beer to save time
yeah i was bending over at the waist trying to hold up my bimini top on my lower back and trying to get my trolling motor out from underneath the bimini top. didnt hurt that day, but ever since that day about 3 weeks ago now, my lower back everyday is hurting. it hurts most in the morning, and when i get up out of the seat, or sitting down, or getting out of bed hurts the most.
i started walking over the weekend, ( i had furball's image of a pair of walking shoes inmy mind), trying tolose about 20 pounds wont hurt either, probably help the back, but i will continue to stretch and take some meds, and if this dont work down the road, ill see someone about it.
Here's some tips that I have learned, since messing up my back in '91.
Don't sleep on a soft mattress. If your mattress is soft, sleep on the floor, or, put a piece of 3/4" plywood between your mattress and boxspring.
(I slept on the floor for over a year! It made a world of difference!)
I wound up buying a 'Select Comfort' (Sleep Number) bed.
Wow!!!! It's incredible! (My number is 85 to 100!)
IF you can sleep on your back, do so. Put a couple of pillows under your knees to press your spine flat and take tension off of the knees.
Lay or lie down (whichever is correct usage) on the floor, in front of your couch, with your legs on the couch, where your rear-end would normally be.
Your rear-end should be where your legs would be, and your head is where your feet should normally be.
I've heard this being called the "Fowler" position.
You should be looking up, toward the ceiling. Arms by your sides.
Stay in this position for about 15 to 30 minutes.
Doing this will press your spine flat, onto the floor and should give you some relief.
When you get up from the bed, or the couch/sofa, etc., start by rolling onto your side, then tuck your knees up like you are getting into the fetal position, then swing your legs down to the floor, and using your arms, push yourself up to the sitting position.
This will keep your spine more supported and straight(er).
When I messed up my back, I lost a year and a half from work.
I had two really good doctors taking care of me.
I had a 'cheat sheet' around here, somewhere, that has a lot of good information about sitting up, laying down, exercises, etc., and not aggrivating your back.
If I can find it, I'll post it. I think my wife put it in the file cabinet, downstairs.
If that's the case, it'll be found in another 100 years or so.
Use a regular size towel, roll it TIGHTLY so it won't collapse under your body weight, hold it together with a couple strips of duct tape.
Good luck.
sorry for the long post but i want to make sure you understand that if its been a few weeks and it doesnt go away get help before you end up like me.
tony
and they will knock it out. I had recurring bursitis in my shoulder that was injured in
my head on collision (ironically from the seatbelt) Every now and then I would move
wrong or my shoulder would pop out of socket and I would have to slam it back in.
Finally after 3 weeks of constant pain and barely using it I went to a massage therapist kind of helped. I finally called a accupuncturist and went there expecting a
big bunch of hokem and crap but they said what is wrong and had me lay down and
put like 30 needles in my shoulder, hooked it up to a electrolysis machine and a infra red lamp, after 20 minutes she said I was done come back in 1 week. I thought great
here we go get me coming back again and again, It actually started feeling good on
the way home and for the next couple days, So I went back and told her how my neck
was also hurting so she stuck 20 or so in there too, I guess with the shoulder not hurting I started to feel my neck pains. She said come back next week and I went back and had the arm and neck done again even though my shoulder was feeling good
At the end of that treatment she said you are done no more treatments!! It has been
2 1/2 years and no pain from the shoulder at all and not once has it popped out of joint either. I would say try to find a real chinese doctor since they have been around
it and know what they are doing. It cost me $150.00 plus like $30.00 for some herbs
she had me take. That is basically like going to a specialist for three visits plus all the
other crap your GP is going to have you do. It is worth a shot if you are tired of pain
and taking drugs forever. You barely feel the needles they are smaller than a Hi E string on a guitar and don't go in farther than a half inch it looked like into my shoulder.
