I have been recently having an issue with my truck that i believed to be the parking brake sticking...but i believe i have ruled that out.
When the truck has sat for a while, just a matter of a few hours really, and i put it in drive, i literally have to put the accelerator on the ground to get going. At which point the truck will rev up then slowly begin to move.
I noticed the other day, that i dont have this problem in reverse. So instantly the idea of tranny issues popped into my head.
that sounds logical, but i believe it still shifts 2 more times. It doesn't shift into 2nd easily on a cold morning though. Il have to get it up to about 20 or so and then let off the gas for her to shift.
just a thought, but when is the last time a maintenance was done on the tranny such as filter screen cleaning and replacing fluid? not real up on diesel auto trannies, but the c-4 i had in a car had problems shifting when stuff got nasty. also had a bad modulator that had to be replaced. i would have to wind engine up about 2,000 beyond shift point and let off for it to shift up gears. same as you, no problems with reverse. not sure if the c-6 has oneof those or not, but if so, that may be something to look at.
sounds like the tranny doesn't have enough main line presure when cold, the revers clutch gets more presure than the forward clutches. check your fluid and let us know what color it is and what it smells like.
I have seen torque converters do this very thing. Rare in my experience but they can does this. I ran into a Chevy van with a 6.2 in it several years ago that a guy brought me. It was the converter. I had a old auto trans guy put me on to the coverter. He explained to me what happens inside that causes it.
Anybody else remember the engine brakes that Cat used to put on their engines that used engine oil. The Brake Saver. It has that effect.
It was a retarder that Cat used/uses in place of a jake brake. They worked off oil pressure. Either one was an option for the Cats. The retarder held better than jakes as long as the oil didn't get to hot. You had to keep an eye on the retarder temp and dump the oil when it got hot.
Overall, on a long downgrade, you could raise the total oil temp 20-30 degrees. Retarder was heavier than jakes, about 800lbs if I remember right.
There are several adjustments......... linkage, VRV setting, and PNP switch also a band tightening any or all may be contributing to the problem.
WAG..... I have heard of the band being too loose, due to the interconnect piece between the adjuster and the band falling out ....... IIRC that would be the symptoms you are getting. I would advise to drop the pan again and see whats in the pan.
"I have seen torque converters do this very thing. Rare in my experience but they can does this. I ran into a Chevy van with a 6.2 in it several years ago that a guy brought me. It was the converter. I had a old auto trans guy put me on to the coverter. He explained to me what happens inside that causes it."
Could be the torque converter leaking back into the trans. I have seen this in some cases. Also have seen the pump seal go and allow the same thing. once the TC gets filled back up, it is able to do its thing properly and works fine. if you check the level cold you may see an elevated fluid level. Should be no external leaking either.
The van that had the bad converter had nothing in the oil that was out of the ordinary and fluid level was fine. Rare failure. It would shift through all the gears and would run out ok out on the road but when you stopped and took off it was like you were tied to a train. You could floor it and it would slowly take off and the motor was lugging hard.
