Anyone with A&P/Avionics experience?
Old Feb 20, 2008 | 11:19 PM
RangerPilot's Avatar
RangerPilot
I picked up this VOR indicator at a gun show in Dallas a while back. I'm trying to get some info on it, mainly to try and figure out what kind of plane it might have been installed in.
The stamp on top says "6 JUIL 1973".
Below that there is a sticker that says:
"<BL> Brion, Leroux Paris
No 708
Type 3874M
Ref (blank) V (blank)
Date 12 66 Cle <BL>"
Then a riveted tag that says:
"S.T.T.A
ID-71-(some ground out digit) then scratched in: B
Marche 65-80277 No Sie 598
Cle D Fin Recette 30.12.66
No 1157 Socrate"
On the front the OBS **** says "Tirez", I ran it through a French translator, came back as "Draw". The OBS **** is pull to adjust, not push to adjust. The selector around the OBS **** toggles the indicator in the gauge from AUTO to ILS.
The back has some odd connector as seen in the pictures, covered by a metallic screw on cover. It looks like a screwdriver would allow you to tighten and loosen it, perhaps for a ground?
The main connector is a 32-pin plug, has alphanumeric numbers around the pins, the "grooves" to make the plug only accept a certain type of hookup are one large one at the top, two smaller ones right next to each other on the lower-left, and two smaller ones farther apart on the bottom right.
Thank you all for any help you can provide:
Old Feb 21, 2008 | 01:17 AM
littleme13's Avatar
littleme13
looks like a military box, tags look similar to the ones we had on our p3 but im not positive. also US sold a bunch of them to european contries. ill have to wait till tommarow to call an old friend to see what he thinks but it might be hard with the numbers not being the same.
Old Feb 21, 2008 | 09:29 AM
Chugalug's Avatar
Chugalug
Looks like a Gyro Compass to me, but it has been about 40 years since I have seen one.
The connectors on the back were called Cannon Plugs.
Old Feb 21, 2008 | 10:10 AM
Bart99GT's Avatar
Bart99GT
Its definitely a VOR - LOC/GS indicator.
Old Feb 21, 2008 | 11:25 AM
RangerPilot
Thanks littleme13, that'd be great if your friend knows anything about it. I as well through it looked like a military unit (definitly doesn't look like anything in our planes). If there's anything else I can do to help him out, let me know.
I got it from an older gentlemen who said he had bought it from a pilot friend. He had no idea on it's history other than the dates stamped on top.
Chug, thanks for the name of the plugs, I always wondered that.
Thanks for the help guys, hope to hear even more soon.
Old Feb 21, 2008 | 04:53 PM
CretePumper's Avatar
CretePumper
found a matching ADF, a little before my time, but from what I gathered they were used in the French Air Force's CM-170 \ CM 170-2 Fouga Magister Twin jet trainers a.k.a. (flying School houses) and some Rotorcraft. First flight of the CM 170 was flown on July 23 1952 and was the world's first jet powered trainer.
Old Feb 21, 2008 | 06:02 PM
RangerPilot
Very cool, thanks for that CretePumper. Good info, cool looking ADF as well. Nice to get some history on the unit itself.
Old Feb 21, 2008 | 06:28 PM
littleme13's Avatar
littleme13
sorry ranger my friend couldnt find anything but hes one of those guys that if he doesnt know off the top of his head where to look he wont dig for anything. im still waiting on an email from one other who is a electrical engineer for the military to see if he has anything more.
tony
Old Feb 21, 2008 | 06:58 PM
CretePumper
Here's a jumpseat shot of the panel of the CM-170/ FM-67, this is the Finn set-up Localizer is situated on top left of panel French set-up is LOC on bottom right, I'm guessing.
another set-up LOC on bottom right
Perhaps you may find this interesting, a little history of the CM-170
http://en.wikipedia.org/wiki/Fouga_Magister
Old Feb 21, 2008 | 07:28 PM
RangerPilot
Thank you both. That's some pretty good info on the CM-170. Nice to know at least some history on where the unit could have come from. It does bear some resemblence to the unit in that picture, so I figure it's probably a later model since the plane was made for so long.
72CC428
Nov 30, 2016 08:54 PM
Furyus1
Apr 6, 2012 11:03 PM
Sterling Archer
Nov 4, 2011 03:01 PM
racsan
Jul 20, 2011 11:24 AM
