Axle mystery
Old Feb 20, 2008 | 08:24 PM
LuckyLuke's Avatar
LuckyLuke
Axle mystery
Hello everyone, thank you in advance for any time spent helping me. I have done some extensive forum searches for info on this particular axle with no sucess. I have a 72 f250 crewcab with some mods. It looks like someone may have put a different axle in the rear. It has a 70 (I think) cast into the top of the housing and the numbers 030788 cast into the back of the housing. There are no numbers stamped into the axle tubes but the tag reads 603179-4 DO1A-AD with a 4:10 ratio. The tubes look to be 3.5 inches with drum brakes, it is a dually. It also has a 10 bolt cover. I haven't pulled the cover off yet. I have looked every where for these bom numbers with no luck. I'm just trying to find out what I have for future reference. Anyone?
Old Feb 21, 2008 | 09:23 AM
Freightrain's Avatar
Freightrain
Sounds like a Dana 70? Usually that number is the type/size of housing, ie: 44,60,70
I'm not up on Dana's so I might be out in left field? Being a dually/1 ton, I about bet though I'm right.
Welcome to FTE!
Old Feb 21, 2008 | 09:10 PM
Customcab's Avatar
Customcab
Not sure / an expert on this or any subject; just wanted to welcome you aboard. Post your vin data and it might help with the overall decoding; or better yet look (Some great FTE folks have developed a reference site) at the top of this page under Article/ Specs; scroll down to vin decode and it might help ya.
Again welcome aboard.
Mitch
Old Feb 21, 2008 | 09:21 PM
wizzard351's Avatar
wizzard351
70's were duelly axles and as stated abouve the number is cast into it so if yours has a 70 on it thats what it is
Old Feb 21, 2008 | 09:26 PM
51dueller's Avatar
51dueller
Sounds like a Dana 70. The closest BOM I can find is a 603180 and that's a 1970 Dana 70. The D01A would say it was originally designed for a 1970 vehicle. Here's a picture of my 1969 Dana 70. Just ignore the swaybar as that is off a later truck.
Old Feb 21, 2008 | 09:58 PM
LuckyLuke's Avatar
LuckyLuke
Thank you all for the welcome and info, had no idea the DO1A made it a '70. Looks just like the picture. Would still love to find the exact vehicle this thing came out of just can't trace that BOM number. This was my first post on any forum, I appreciate not being burned at the stake like I've seen in other forums.
Old Feb 22, 2008 | 10:59 AM
Freightrain
Oh, don't worry, we'll give ya heck some other time LOL!!!!!!!!!!!!
Glad we could give you some direction!
Come on back anytime.
Old Feb 22, 2008 | 11:53 AM
SAlexander's Avatar
SAlexander
Likely from an F350 DRW. Easy and common swap. Does your truck have the dually hubs and wheels in front too? If not, I believe the DRW stuff will work on your spindles if you can find it. That way all your wheels will be the same. You could even use the DRW front hub/rotors/calipers from a '73 and newer truck and upgrade to disc brakes.
Old Feb 22, 2008 | 07:15 PM
TigerDan's Avatar
TigerDan
Hi and Welcome! Glad your first posting experience was a good one. We aim to please...(unfortuately, sometimes we miss!)
Old Feb 22, 2008 | 11:37 PM
Crackpot's Avatar
Crackpot
Dully front? like as in 4 wheels.. sorry, I got a laugh...
Old Feb 22, 2008 | 11:46 PM
SAlexander's Avatar
SAlexander
....Never mind............
Old Feb 23, 2008 | 08:23 AM
Freightrain
Meaning the offset hubs to run tandem style rims.
If the front axle has standard style rim, then it was not a dually originally.
Old Feb 23, 2008 | 11:24 AM
Crackpot's Avatar
Crackpot
I know, the 4 wheel thing popped into my head and I had to share.. it was just a funny ha ha thing.
Old Feb 23, 2008 | 03:04 PM
LuckyLuke's Avatar
LuckyLuke
The front axle on the this truck is actually off of a '77 f250 and is an open knuckle dana 44 hd. Some one converted this to a 4x4 before I bought it. I have recently put a 460 in it with some performance improvements. It's been a bit of a challenge tracking down what this truck really is. The vin # indicates it was originally a 2 wd with a 300 six cyl. Not sure what the emissions people are going to call it. Thanks to everyone for the input.
