Offroad & 4x4
front end advise
Old Feb 20, 2008 | 06:17 PM
dcammuso's Avatar
dcammuso
front end advise
i'm looking to put disc brakes in the front end of my 1954 Ford F350 the most cost effective way. now i have a parts truck(1980 ford f350) that i could mate the front section of frame, to the 1954 frame say like at the fire wall. or should i just buy the disc conversion kit form LMC that's around 600 dollars. now the only other problem i have with this is i put in a 1 ton rear end with 16 inch dual wheels and i need the the front wheels and tires to match the rears and its smaller and has a different bolt pattern than the stock 1954 wheel witch is i believe 5 studs 4.5 iches on center. if anyone has a suggestion or comment i will take anything thanks.
Old Feb 20, 2008 | 06:39 PM
captain p4's Avatar
captain p4
I think that 1980 F350 is going to be a TTB front end. What are the plans for the truck? The best way to go if you're going to put larger offroad tires on it would be a dana60 or dana44 with 8 lug outers (below 38" tires for the d44).
More info is needed on what you're going to use the truck for to give a solid answer
Old Feb 20, 2008 | 07:53 PM
kjett's Avatar
kjett
Heck for that matter, is it even 4wd or is it 2wd? That's make alot of things different
Old Feb 20, 2008 | 08:26 PM
Ford150/428/dud's Avatar
Ford150/428/dud
dcammuso
Your post is a bit confusing, tooo much words and not alot of meaning.
Old Feb 20, 2008 | 09:04 PM
countryboy116's Avatar
countryboy116
i thought that the F350s were the ones that got the solid front axle in those years
Old Feb 20, 2008 | 09:08 PM
captain p4's Avatar
captain p4
80-85.5 ttb.
dark time in ford history.
we don't talk about it much.
Old Feb 20, 2008 | 09:10 PM
countryboy116
damn even in the 350s? wow ur not kiddin, a very dark time indeed
oldford54
Dec 28, 2012 09:48 AM
Bill Thunder
13
Nov 9, 2012 09:50 AM
Yeehaw1
May 24, 2012 02:21 PM
medicpg
May 21, 2003 04:41 PM
medicpg
May 20, 2003 07:39 PM
