General Automotive Discussion
Greasing Your (trailer) Balls?
Old Feb 21, 2008 | 01:24 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I have always greased my *****...always.
Gawd....that sounds so dirty!
Old Feb 21, 2008 | 02:23 AM
Monsta's Avatar
Monsta
Sit. Stay.
One thing about greasing your ball... ew...that does sound dirty...anyway...some trailers rely on the contact to complete the grounding for the lights. (4-pin) grease may interfere with that. Just make sure you check your lights.
Old Feb 21, 2008 | 04:29 AM
four-sixty-power's Avatar
four-sixty-power
Why worry about the ground? Here's the diagram:
http://www.offroaders.com/tech/image...ing-4-wire.jpg
and 7-Pin:
http://www.western-towing.co.uk/acat...ler_wiring.gif
http://www.offroaders.com/tech/image...uck-wiring.gif
and the search I used:
http://images.google.ca/images?hl=en...-8&sa=N&tab=wi
Old Feb 21, 2008 | 06:17 AM
Manitoulin's Avatar
Manitoulin
Your to grease your ***** cause when u make left turns you could loosen your ball. It has happen to few people.
Old Feb 21, 2008 | 08:02 AM
Bill W's Avatar
Bill W
I hate Loose *****, I'll keep a little grease on them! Thanks Guys.
Old Feb 21, 2008 | 12:46 PM
blue beast's Avatar
blue beast
If you don't lube it at least every now and then the little foot in the hitch will wear out
and then it could slip off!! A bit of white lithium or if you are worried about the greasy
feeling ball, Use some spray graphite or the pb TDL (teflon dry lube) I prefer the dry lube route if it is on a small trailer that might get dropped in the dirt and wet grease
would grab dirt and crap. You should actuelly every so often inspect the hitch internals for wear and rust on the spring and either replace or clean and relube.
Old Feb 21, 2008 | 04:05 PM
PROSTOCK's Avatar
PROSTOCK
I lube mine with petroleum jelly...really I do! Grease stains wash out of your pants easier, and it has a nice fresh sent if you get the scented stuff. Tried it once on our 5'r after listening to the squeeking on the way to the campsite. I only had petroleum jelly (got kids in diapers? you got petroleum jelly) used it and it worked, so that's what I've used from then on.
Not lubing your ***** is stupid!
Old Feb 21, 2008 | 05:24 PM
cdrmotorsports's Avatar
cdrmotorsports
Wait, you smell your *****?
Seriously tho, stated before by me and Monsta, watch the grounding on smaller older trailers that still ground on the ball.
Nothing like having a bad ground or an electrical short on your *****.
Maybe if you use them more often you won't have to lube them? Man I'm on fire today.
Old Feb 21, 2008 | 09:30 PM
Bruker's Avatar
Bruker
I usually have my wife grease the *****.
Old Feb 21, 2008 | 10:07 PM
LxMan1's Avatar
LxMan1
I keep alot og grease on my ball and I have had no problems except the occasional ball grease on my leg if I bump into it. I ususally leave the hitch out of the reciever unless I am using it. It is too big and bulky to leave in there since it is a weight distributing hitch.
Old Feb 24, 2008 | 07:50 PM
gezn2's Avatar
gezn2
I've always lubed mine, it just seemed like sensible preventive maintainance
I've run across a few beat up hitches that won't stay latched once they've been lubed but I've always used a padlock for a**hat prevention, so that's never been a problem anyway.
Old Feb 25, 2008 | 04:55 PM
ckal704's Avatar
ckal704
I never used to grease my *****, but now that i am a little older, I am open to new ideas.
I like Bruker's idea. I'll get the wife to do it for me. She is always complaining that I am stuck in a rut.
Old Feb 26, 2008 | 12:55 PM
  #28
spikedog's Avatar
spikedog
Other than being a dust magnet, I don't see the problem with greasy *****. I sure wouldn't want it to bind up and loosen the ball on a left turn. Talk about a long cheater bar!
Old Feb 26, 2008 | 01:28 PM
  #29
MisterCMK's Avatar
MisterCMK
If your lights rely on the trailer ball for the ground it is time to re-wire the trailer.
As far as greasing the trailer ball, I do if I am towing a long distance with a heavier trailer (ie, over 3,000lbs).
Old Feb 26, 2008 | 04:18 PM
  #30
FLgargoyle's Avatar
FLgargoyle
If grease would cause a trailer hitch to slip off, you better not grease your tie rods! I agree that grounding through the ball is not a good idea. Even without grease, it can lead to erratic light problems.
