Help Needed In Az
Old Feb 20, 2008 | 04:08 PM
supr_sly's Avatar
supr_sly
Help Needed In Az
I live in <st1><st1:city w:st="on">Casa Grande</st1:city>, <st1:state w:st="on">AZ</st1:state></st1> and just bought a 28 ft toy hauler. It came with a reeses WD hitch and a friction sway bar. The gut I got the TH from had a lifted truck so when I hooked it to my 2X4 6.0 EX the trailer nose were almost touching the ground. First how level should the trailer be. The 2<sup>nd</sup> is how should you set up the sway bar? if any one is willing to come out and help i would buy you a beer or two maybe 3 if thing go smothly
Old Feb 20, 2008 | 05:15 PM
Monsta's Avatar
Monsta
Sit. Stay.
How much drop does you tow bar have?
There really is no degree of level. It either is or isn't. The trailer should be level or ever so slighty low in the front to help compensate for when you brake.
Old Feb 20, 2008 | 05:50 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy
can you post a picture of your setup?...that would help me figure out what we are dealing with...
If you cannot post a picture...let me know and I'll send you an email addy for you to email the pictures to me for posting...
As Monsta said...the TH should be as close to level as possible and if not possible...a slight nose low on the TH is preferred next.
The friction bar is easily installed on the two smaller diameter ***** (one on TH and one on hitch head). You tighten until pretty tight and then back off to keep the handle parallel to ground...
Get me some pictures and I can help you dial her in...I'll have to take a pass on the brewsky though until we meet some day!...I'm headed to Williams AZ this summer...
joe.
Old Feb 21, 2008 | 12:08 AM
supr_sly's Avatar
supr_sly
Thanks
thanks for the help .i will try to get some pix tomorrow.
Old Feb 24, 2008 | 05:17 PM
supr_sly's Avatar
supr_sly
this is my setup
i moved the ball all the way to the top I would like to know if is can flip the drop hitch over so I can raise the ball more . I will try to post some pix
<o> </o>
<!--[if gte vml 1]><v:shapetype id="_x0000_t75" coordsize="21600,21600" o:spt="75" oreferrelative="t" path="m@4@5l@4@11@9@11@9@5xe" filled="f" stroked="f"> <v:stroke joinstyle="miter"/> <v:formulas> <v:f eqn="if lineDrawn pixelLineWidth 0"/> <v:f eqn="sum @0 1 0"/> <v:f eqn="sum 0 0 @1"/> <v:f eqn="prod @2 1 2"/> <v:f eqn="prod @3 21600 pixelWidth"/> <v:f eqn="prod @3 21600 pixelHeight"/> <v:f eqn="sum @0 0 1"/> <v:f eqn="prod @6 1 2"/> <v:f eqn="prod @7 21600 pixelWidth"/> <v:f eqn="sum @8 21600 0"/> <v:f eqn="prod @7 21600 pixelHeight"/> <v:f eqn="sum @10 21600 0"/> </v:formulas> <vath o:extrusionok="f" gradientshapeok="t" o:connecttype="rect"/> <o:lock v:ext="edit" aspectratio="t"/> </v:shapetype><v:shape id="_x0000_i1025" type="#_x0000_t75" style='width:431.25pt; height:323.25pt'> <v:imagedata src="file:///COCUME~1slbosonLOCALS~1Tempmsohtml1\01clip_image 001.jpg" o:title="Copy of truck and trailer 002"/> </v:shape><![endif]--><!--[if !vml]-->[img]file:///C:/DOCUME%7E1/slboson/LOCALS%7E1/Temp/msohtml1/01/clip_image002.jpg[/img]<!--[endif]-->
<o> </o>
<!--[if gte vml 1]><v:shape id="_x0000_i1026" type="#_x0000_t75" style='width:431.25pt;height:323.25pt'> <v:imagedata src="file:///COCUME~1slbosonLOCALS~1Tempmsohtml1\01clip_image 003.jpg" o:title="truck and trailer 003"/> </v:shape><![endif]--><!--[if !vml]-->[img]file:///C:/DOCUME%7E1/slboson/LOCALS%7E1/Temp/msohtml1/01/clip_image004.jpg[/img]<!--[endif]-->
<o> </o>
<!--[if gte vml 1]><v:shape id="_x0000_i1027" type="#_x0000_t75" style='width:431.25pt;height:323.25pt'> <v:imagedata src="file:///COCUME~1slbosonLOCALS~1Tempmsohtml1\01clip_image 005.jpg" o:title="truck and trailer 004"/> </v:shape><![endif]--><!--[if !vml]-->[img]file:///C:/DOCUME%7E1/slboson/LOCALS%7E1/Temp/msohtml1/01/clip_image006.jpg[/img]<!--[endif]-->
<o> </o>
<o> </o>
<!--[if gte vml 1]><v:shape id="_x0000_i1028" type="#_x0000_t75" style='width:431.25pt;height:323.25pt'> <v:imagedata src="file:///COCUME~1slbosonLOCALS~1Tempmsohtml1\01clip_image 007.jpg" o:title="truck and trailer 007"/> </v:shape><![endif]--><!--[if !vml]-->[img]file:///C:/DOCUME%7E1/slboson/LOCALS%7E1/Temp/msohtml1/01/clip_image008.jpg[/img]<!--[endif]-->
<o> </o>
The X is at its ride height I think this is were I would like the TH so I need 6’ of lift I think ?????
Old Feb 24, 2008 | 05:30 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy
Nothing is displaying...you need to have a host site like webshots or the like.
I 'think' you can post them to your gallery here and link to them then?
joe.
Old Feb 24, 2008 | 06:04 PM
Monsta's Avatar
Monsta
Sit. Stay.
6 feet is a awful lot.
You can flip the ball mount. But having those pictures would be best for all of us to give advice.
You should be able to add them to your free gallery space and post them here or direct us to look in your gallery.
Old Feb 24, 2008 | 06:07 PM
scottman70's Avatar
scottman70
Does the hauler have the axles flipped? If the guy you bought it from had a lifted truck, thae axles may be flipped??? That would make it hard for you te get any hitch up high enough for the hauler to be level.........By the way what kind of trailer did you buy??
Old Feb 24, 2008 | 06:23 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
I have a Weekend Warrior FSW 3200 triple axle with flipped axles and to get the truck and trailer to ride even I need to go way high on the shank to make it work
Old Feb 24, 2008 | 06:34 PM
scottman70's Avatar
scottman70
That's not pretty, but it will work! You could lift the Ex....How does it tow the Warrior??
Old Feb 24, 2008 | 08:31 PM
supr_sly's Avatar
supr_sly
look in my profile
i uploaded som pic's i will try to get some more but it is dark here now i hope this work better
Old Feb 24, 2008 | 09:49 PM
weekendwarriorfsw32
Master of Strokes
Ya I tried to tell my dad that but he didnt go for it but at first when we towed it, it was the scariest thing to drive now we have got it to tow perfect,
Old Feb 24, 2008 | 10:12 PM
i eat hybrids's Avatar
i eat hybrids
Was the 6.0 all over the road like the other Ex's? What mods did u do? it doesnt say in ur sig.
Old Feb 24, 2008 | 10:57 PM
weekendwarriorfsw32
Master of Strokes
Ya it has a Hell wig anti sway bar and 08 mirrors.
Old Mar 5, 2008 | 08:59 PM
supr_sly's Avatar
supr_sly
flipped
i just foud out what you ment by flipped. the sptings are on top of the axels and the is a small speacer also. can anyone give me any hints on switching them, wich i will be doing in the moring.
p.s.
it is an 26', 04 gearbox
