swapping 460's
Old Feb 20, 2008 | 02:36 PM
fdude64's Avatar
fdude64
swapping 460's
i have an extra 460 that came with my truck i am planning on swapping them. other than pulling the oil pan and looking at the bottom end is there anything else i should do before doing the swap? cam timing? or anything
Old Feb 20, 2008 | 03:09 PM
Handegard's Avatar
Handegard
I'd do a timming chain/gears, and replace any gaskets that show the slightest sign of oil seeping out.
An oil pump would me far easier to do on a stand, for that extra little protection.
Yeah, I'd do timming, oil pump, and water pump. That'd be a pretty good freshening up on a stand...
Old Feb 20, 2008 | 03:44 PM
fdude64's Avatar
fdude64
i have heard alot about advancing valve timing from stock as much as 4 degrees any ideas about this?
Old Feb 20, 2008 | 04:15 PM
monsterbaby's Avatar
monsterbaby
depends on what year the engine is first off. the early ones don't need a different timing chain. (it's cam timing they are talking about) basically buy an aftermarket double roller timing chain and install it straight up (zero position on the gears) and this will give you back the correct cam timing. might not be a bad idea anyway depending on mileage because a lot of the factory timing sets used Nylon gears and over the years those get brittle and break or the chain maybe stretched etc so if nothing else at least pull that timing cover and look at it (gaskets are cheap)
Old Feb 20, 2008 | 07:15 PM
fdude64's Avatar
fdude64
well all i know is it is a 1973 460. ran good when taken out of what ever it was in
Old Feb 24, 2008 | 06:17 PM
fdude64's Avatar
fdude64
when you say zero position on the timing gears do you mean line up the marks? or do i set it somewhere else?
Old Feb 24, 2008 | 08:15 PM
monsterbaby
if it is a double roller aftermarket chain it will have 3 or more positions on it, check teh instructions but most have a 0 setting and you just line that mark up with the timing mark on the cam gear and that should be straight up.
Old Feb 24, 2008 | 08:17 PM
fdude64's Avatar
fdude64
ok thanks i thought that was what you meant i feel stupid asking
Old Mar 4, 2008 | 04:34 PM
fdude64's Avatar
fdude64
what year did they start the valve timing set back for emissions?
Old Mar 4, 2008 | 05:25 PM
monsterbaby
As I recall it was 72.
Old Mar 4, 2008 | 06:24 PM
fdude64's Avatar
fdude64
i was wrong about the year of my spare motor. it is a 71 block with 73 heads. will i still need the straight up timing chain set?
Old Mar 4, 2008 | 06:26 PM
kjett's Avatar
kjett
Just out of curiosity, isn't the timing mark on the straight up set use the same location on the cam gear, just in a different spot on the crak gear? And the stright up set has the mark located in line with the crank key. So if that were the case, couldn't you just move the crank slightly until the keyway lines up with the cam gear mark? I know it's not the best way do do it, but was just thinking that if the chain was fairly new, then why spend the extra $$ to get a different chain set that had a re-indexed mark. Thoughts, or am I just being a cheapie???
Old Mar 4, 2008 | 06:51 PM
fdude64's Avatar
fdude64
not worried about spending the money for the 0 set just dont want to buy something i dont really need.
Old Mar 4, 2008 | 07:00 PM
monsterbaby
They used D1VE blocks from 71 until 78 and the D3VE heads were used from 73 until the switch to FI in 87 (some did have F5 casting number but from what all appearences are identical to D3 heads)
Old Mar 4, 2008 | 07:14 PM
fdude64's Avatar
fdude64
so which timing set should i get? o degree or standard?
