Compression Ratio
Old Oct 3, 2002 | 06:58 PM
1bad400's Avatar
1bad400
Compression Ratio
Old Oct 3, 2002 | 10:43 PM
jopey's Avatar
jopey
Compression Ratio
I am researching on rebuilding a 400ci with the 9:1 CR pistons. People are telling me I am not going to be able to run these with out pinging on 91 octane gas.
Some one said if I polish the insides of the heads where the combustion chamber is I will be not pinging at all.
Please advise me :-)
Old Oct 4, 2002 | 01:34 AM
Brian S's Avatar
Brian S
Compression Ratio
9:1 should not be a problem with 91 octane. If you polish the chamber, it may help. Do it before a valve job and put a couple junk valves in to protect the seats. Don't get carried away trying to make them perfect.
Old Oct 4, 2002 | 11:56 AM
beartracks's Avatar
beartracks
Compression Ratio
Ditto.
