Oil Sending Unit
Old Feb 20, 2008 | 10:33 AM
64blue's Avatar
64blue
Oil Sending Unit
Any Ideas on getting the oil sending unit out of the manifold on a 351M. Its a 9/16 nut under the unit and you can only use a short open end wrench because its so close to the fire wall. I cant budge it.
Old Feb 20, 2008 | 10:51 AM
masterbeavis's Avatar
masterbeavis
I used a wrench that I bent into a 30* angle to clear the manifold. I thought I used a 5/8 wrench?? Worst case, you get a helper to hold the wrench while you kick it. (it sounds stupid, but that is what I think I wound up doing, using my foot, but that was forever and a year ago....) If you dont plan on re-using it,you could breakit off and get it with a socket? Not sure if its worth the labor tho.
Old Feb 20, 2008 | 10:58 AM
tractoman's Avatar
tractoman
Can you reach it with a crowsfoot wrench?
Old Feb 20, 2008 | 11:14 AM
masterbeavis
I dont think the crows foot is long enough?
Old Feb 20, 2008 | 11:19 AM
64blue's Avatar
64blue
Im replacing it. It seems to be leaking. Ive got an oil leak near the top of the engine but only when it is running. Im trying the cheapest fixes first. I dont think its the intake gasket. Ill try the bent wrench and foot method.
Old Feb 20, 2008 | 01:12 PM
fmc400's Avatar
fmc400
MSEE
On a 351M the sending unit is on the block toward the back, behind the manifold. It's not actually on the manifold. is this a sending unit for an on\off light or an electrical gauge?
fooledagain
Oct 1, 2012 09:15 AM
SantaRosaBob
Mar 7, 2010 08:53 PM
mrwolf
17
Dec 5, 2006 10:28 PM
mrdj4576
1997 - 2003 F150
Dec 6, 2005 06:48 AM
redbronco2
Bronco II
Aug 17, 2001 10:09 AM
