Cam/Lifter Question
Old Oct 2, 2002 | 08:35 AM
Dillon77's Avatar
Dillon77
Cam/Lifter Question
Hey all,
Anyone ever swap out a cam and lifters without removing the intake manifold? Is it possible? If so, what cautions would you take?
Thanks,
LD
Old Oct 2, 2002 | 09:41 AM
Bill_Beyer's Avatar
Bill_Beyer
Cam/Lifter Question
>Hey all,
>you take?
Maybe it's just too early (I'm only on my first cup o' coffee) but I can't imagine how you'd plan to get the old lifters out much less the new ones in
Old Oct 2, 2002 | 02:40 PM
blu93gt's Avatar
blu93gt
Cam/Lifter Question
[updated:LAST EDITED ON 02-Oct-02 AT 03:58 PM (EST)]yes - you need 16 magnets, each on the end of a wire (preferrably aluminum wire). pull each lifter up in it's bore about 3/4" and bend the wire over the valve cover rail to hold it up. after you change the cam, use a stick or something through an adjacent pushrod hole or the opening between intake ports to hold the lifter down when you pull the magnet off.
but you should use new lifters with your new cam!
okay - just drop the oil pan, the rod caps, and the crank. push all the pistons up in their bores, pull the lifters up with magnets as described above, pull the cam, then remove the magnets, using hold-down stick as described above. the lifters should just fall out. position the magnets as before, and install the new lifters. install the cam, then remove the magnets, using hold-down stick as described above. then just put everything back together and you're done!
it would probably be easier to just take off the intake!
Old Oct 2, 2002 | 03:34 PM
jopey's Avatar
jopey
Cam/Lifter Question
don't they sell a tool to pull the lifter out thru the heads?
Old Oct 2, 2002 | 03:53 PM
Bill_Beyer's Avatar
Bill_Beyer
Cam/Lifter Question
>the magnet off.
>done!
See now you're not letting gravity work for ya! How's this...turn the truck upside down so the lifters all stay up in the bore then pull the pan, change the cam, etc. That way you only need 1 magnet instead of 16...much cheaper and this way you can drop the new lifters right in!
Old Oct 2, 2002 | 04:43 PM
Brian S's Avatar
Brian S
Cam/Lifter Question
"don't they sell a tool to pull the lifter out thru the heads?"
The opening in the heads is only about 5/8". Plenty of room for a pushrod but the lifters can't pass through.
They make a tool to pull the lifters out far enough to get a cam out but it is for roller cams only. http://66.96.130.106/archives/2002/07/camswap/index.shtml
Old Oct 4, 2002 | 02:07 PM
garypettengill's Avatar
garypettengill
Cam/Lifter Question
Depends on the engine you have. The 351M/400 heads have openings in them that will allow the lifters to be removed without pulling the intake. I know, I've done it. Mind you it takes patience, but it can be done.
Old Oct 4, 2002 | 04:47 PM
shazam's Avatar
shazam
Cam/Lifter Question
They Do ???
Old Oct 4, 2002 | 05:03 PM
Brian S's Avatar
Brian S
Cam/Lifter Question
OK. I stand corrected. I looked at my 4V heads and said no way. The 351M/400 have an area large enough for a lifter to pass through. They aren't lined up with all the lifters so it looks like a miserable job. If you have "building a ship in a bottle" skills and patience go ahead. It would take me 10X longer than pulling the intake.
Old Oct 6, 2002 | 03:33 AM
GT40man's Avatar
GT40man
Cam/Lifter Question
basicly, no. just jull the intake and save like a weeks worth os cursing.
Old Oct 6, 2002 | 03:34 AM
GT40man's Avatar
GT40man
Cam/Lifter Question
17fordguy
Oct 31, 2007 10:31 PM
ErnieX
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
May 2, 2007 01:08 PM
ErnieX
May 2, 2007 01:06 PM
whd507
16
Sep 10, 2002 06:46 PM
MustangGT221
Apr 4, 2002 04:48 AM
