1978 - 1996 Big Bronco
Abs
Old Feb 19, 2008 | 08:08 PM
roostercrows's Avatar
roostercrows
Abs
I have a 92 Bronco with "rear ABS" which dont work at all. What I was wondering is if it is possible or realistic to put a full ABS system on my Bronco.
Did any of the later years come with full ABS that worked?
Thanks
Old Feb 20, 2008 | 01:29 PM
Bimmerboy1989's Avatar
Bimmerboy1989
Is the light on or did someone unplug the module. I had a 90 Ranger with the same system. My truck was taken to the shop by the previous owner. They "fixed" the RABS by unhooking the module. When I got the truck I found the module was unhooked. I did a little research and took a educated guess and replaced the speed sensor in the rear end on top of the pumpkin. I then fired the truck back up and voila the ABS worked again. I would imagine that getting a 4 wheel system would be very time consuming and unneccesary. On that little ranger as hard as I pushed on the brakes the front wheels never locked up.
Old Feb 21, 2008 | 07:28 PM
roostercrows
thats my problem, the fronts lock up all the time in the winter and then I have no control.
I dont think that the RABS has been disconnected but I will look into it.
Old Feb 22, 2008 | 10:48 AM
Bimmerboy1989
ah, well Iguess I don't think about snow and Ice when I talkbout ABS. I live in texas. But I'm sure you could upgrade that ABS to 4 wheel. gonna need a wiring harness and stuff.
Old Feb 22, 2008 | 12:32 PM
Conanski's Avatar
Conanski
Originally Posted by roostercrows
thats my problem, the fronts lock up all the time in the winter and then I have no control..
Winter tires will all but cure that problem.
smittys5xs
Mar 12, 2015 10:11 PM
Rudiak
Apr 11, 2014 08:13 PM
hatchet
16
Dec 25, 2010 11:47 PM
Kemicalburns
Jun 26, 2007 01:45 PM
mike
1983 - 2012 Ranger & B-Series
Nov 18, 1999 10:22 AM
