Need Help With 95 Stroker
Old Feb 19, 2008 | 07:33 PM
95STROKER29's Avatar
95STROKER29
Ok Here Is What It Is Doing,first Truck Smokes When Cold,not As Bad When Plugged In,but When It Warm Up It Stops,second After Truck Shifts Into Od Rpm Surges Up And Down,95 F350 By The Way,is This A Fuel Issue Or Tranny Problem Changed The Rabs Did Not Fix The Problem Please Help
Old Feb 19, 2008 | 07:53 PM
FARM69's Avatar
FARM69
The smoking is probably due to a faulty glow plug(s) or the GPR. Check the GPR first by jumping the two large posts with a screw driver before you crank it up on a cold start (it's located to the right of the alternator). It should spark. Hold it there for about 60 seconds or so and see if this makes a difference in the smoking.
However, it sounds like you have a bad glow plug or two. The easiet way to do this is check the resistance on the plugs. There are 4 valve cover harness, 2 on each valvecover. Remove the pigtail and test the two outside pins. (2 pins per plug, 4 total pins per valvecover). Resistance should be pretty low. Around .3-9 I think. If it reads infinity they are bad.
Also, need a little more information about the truck. Auto/manual tranny? Any mods, etc.
Old Feb 19, 2008 | 07:58 PM
95STROKER29
Transmission Is Auto Think It Is The E4od No Mods But Truck Has About 247,000 On It Do You Think The Rpm Surge Is In The Tranny Od
Old Feb 19, 2008 | 08:01 PM
95STROKER29
Also When I Jump The Gpr,should Key Be On Or Off
FARM69's Avatar
FARM69
I haven't the slightest clue about the E4od. However, there a ton of people on here that no them like the back of their hand. I'm sure they will chime in shortly.
Does it surge when it cold? Warm?
Old Feb 19, 2008 | 08:03 PM
95STROKER29
It Surges Cold And Warm In Od All The Time
95STROKER29
19
Feb 20, 2008 04:03 PM
95STROKER29
New Member Introductions
Feb 19, 2008 07:34 PM
matt95stroker
Mar 8, 2007 08:30 PM
Big Red Stroker
Nov 10, 2004 07:24 PM
