No start
Old Feb 19, 2008 | 06:21 PM
mdacton's Avatar
mdacton
No start
After installing a new trans range sensor truck wont start.
I jumped the solenoid and it fired right up. So I put the old range sensor on it and still wont start with it in the N position. The new one is also adjusted properly with the lines that are on it.
The only thing I can think is the shift cable broke when I was taking it off......the plastic pc. broke. So could that cause any reason for it not to start?
The cable had to be ordered and won't be here til morning
Old Feb 19, 2008 | 09:42 PM
PLC7.3's Avatar
PLC7.3
Are you getting any codes set......... can you check.
Old Feb 19, 2008 | 09:47 PM
mdacton's Avatar
mdacton
no codes, I checked
