410 Fly Wheel
Old Feb 19, 2008 | 02:46 PM
F250army45d's Avatar
F250army45d
410 Fly Wheel
Ok If I Understand Correctly From All I Read On Here I Can Order A Flywheel For A 428 That Was 4 Speed Manual? I Have Been Trying To Find A Flywheel And No Luck Err!!!!!!! Any Clue Where To Get Such A Thing Would Be Helpful.
Old Feb 19, 2008 | 03:01 PM
Bear 45/70's Avatar
Bear 45/70
410s were all internal balanced so a flywheel for a 360 or any other FE will work except the 428.
Old Feb 19, 2008 | 03:38 PM
Redmanbob's Avatar
Redmanbob
Was it ? I thought it used the 428 crank and required the fly/flex plate ? So then there are 3.98" stroke cranks out there alreay internally balanced ? sounds kind of uhmm I dunno I guess once again the FE mystery is eluding me LOL whats new
Old Feb 19, 2008 | 05:27 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
410's from the factory were external balanced same as the 428's.
Try Jegs/Summit. Most of the aftermarket FE flywheels include a bolt on weight for the 410/428 applications.
Old Feb 19, 2008 | 06:00 PM
dinosaurfan's Avatar
dinosaurfan
Smile 410 flywheels
F250Mike, the 410 takes the same flywheel as the 428. All of the 410s were external balance, Bear is mistaken on this one. Any one who sells flywheels or flexplates should be able to get you one. The 410s were offered in Merc's in 1966 and '67. 428s, IIRC were offerd 68-70. Don't let anyone tell you the that the 410/428 'wheel is rare or special or has to cost twice as much. The only differance is the balance. If you can't find one at a good price ready made, you can start with a normal zero balance 360/390 'wheel and have the imbalance you need added at the balance shop. It really isn't that big of a deal. You can weld extra weight on where you need it, or you can drill on the opposite side. DinosaurFan, on work's old 'puter
Old Feb 19, 2008 | 06:40 PM
Bear 45/70's Avatar
Bear 45/70
Strange, Ford says the 410 is internally balanced.
Old Feb 19, 2008 | 09:42 PM
dinosaurfan
Smile flexplates and flywheels
Bear, just when and where is it that Ford says that the Merc 410 was internal balance ? You are the one, and the only, person I know who believes that to be the case. I am going from memory and from Steve Christ's rebuild your FE & FT book. If you don't have a copy, I think motorhaven has them for sale on this site. Or from Amazon, less than 20$ either way. DinosaurFan, on work's old 'puter
Old Feb 20, 2008 | 02:13 AM
Bear 45/70's Avatar
Bear 45/70
How about Ford's Muscle Parts Story Supplement No.1 page 28. But hey It could be wrong.
Old Feb 20, 2008 | 04:42 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
I agree most likely a misprint.
Old Feb 20, 2008 | 05:11 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1966/68 Ford Galaxie/LTD/XL & P/C (Police Cruiser)
C6AZ-6375-A .. Flywheel ~ 428 M/T
Marked: C6AE-6380-B / 184 Tooth Ring Gear / 14 23/64" diameter / (6) 5/16" -18 pressure plate holes on a 12 7/8" bolt circle
This is not the same flywheel a 352/360 or 390 uses, as one can see > >
1965/76 F100/350 & 1965/70 Ford/Mercury Passenger Cars
C5AZ-6375-L .. Flywheel ~ 390 M/T / Marked: C5AE-6380-K / 184 Tooth Ring Gear / (6) 5/16" -18 pressure plate attaching holes on a 12 7/8" bolt circle.
C5AZ-6375-K .. Flywheel ~ 352/360 / Marked: C5AE-6380-J / 184 Tooth Ring Gear / (6) 5/16"-18 pressure plate attaching holes on a 12 3/8" bolt circle.
352/360 uses a 11" inch clutch / 390/428 uses a 11 1/2" clutch
Old Feb 20, 2008 | 06:01 AM
jowilker's Avatar
jowilker
Probably ought to scratch through that mistake, Bear.
E v e r y b o d y knows the 428 crank is externally balanced, including you now.
John
Old Feb 20, 2008 | 11:31 AM
Bear 45/70's Avatar
Bear 45/70
John
Hell, I owned several 428CJs and even raced them. I've know since the CJ appeared it was external balance. Just never fooled with a 410 so took what the book said as fact.
Old Feb 21, 2008 | 01:11 AM
tylstruck's Avatar
tylstruck
A lot of books have misprints.
From my research, the 390 block and interns is the same as a 410. Difference is the 428 crank and shorter connecting rods 6.490". You can reuse anything else in the 390. Including your flywheel, be it any FE flywheel (360/390/410/428), as long as you extenal balance it.
Tyl
Old Feb 21, 2008 | 10:58 AM
dinosaurfan
Smile flywheels
F250, you might look at flywheels from McLeod. Or any of the clutch companies should be able to help you out. But you will have to look at car flywheels, cause the 428 didn't come in a truck. DinosaurFan, on work's old 'puter
Old Feb 21, 2008 | 11:34 AM
Bear 45/70's Avatar
Bear 45/70
Tyl
Actually the 410 and 428 us the same length rods as the 390 and 427. The pistons have the wrist pin moved up .100" to compensate for the longer stroke.
