Whining noise
Old Feb 19, 2008 | 12:40 PM
banjopicker's Avatar
banjopicker
Whining noise
I have a 1987 f-150, there is a whining noise that i cannot figure out,
it is coming from the drivers side behind the drivers door underneath, just wondering if anyone had ran into this problem before. thanks for any replies. I should also say that it does it when in and out of park
Gary
Old Feb 19, 2008 | 01:31 PM
albung's Avatar
albung
frame mounted fuel pump. Turn key to run and leave door open and u will hear it for 2-3 sec
Old Feb 19, 2008 | 03:12 PM
banjopicker
i thought it was fuel pump also, replaced it and filter also, this is a high pitch
noise, it does it when truck is cranked and while driving
Gary
Old Feb 19, 2008 | 05:31 PM
rattosh51's Avatar
rattosh51
Most of them make this noise...common on the older trucks.
Old Feb 19, 2008 | 06:35 PM
Animalistic's Avatar
Animalistic
My power steering pump makes a whining noise but it still works so I'm leaving it alone.
Old Feb 21, 2008 | 12:07 AM
banjopicker
would the fuel selector valve make this kind of noise?
Gary
Old Feb 23, 2008 | 07:02 PM
66F100Again's Avatar
66F100Again
Hi Banjo,
hope you haven't given up on your '66!
Sometimes my wife whines when I'm driving -- and it can be high pitched
I think you might be on to something with the fuel selector switch/valve. If there were an airpocket or pinhole, it might make some kind of noise.
Old Feb 24, 2008 | 03:58 AM
banjopicker
Can the fuel selector valve be unplugged or bypassed, it does'nt switch over
anyway, hasn't for several years, thanks again everyone for your response
Old Feb 24, 2008 | 04:14 AM
highpockets58's Avatar
highpockets58
Maybe there's a C***y guy stowed away somewhere in your truck.....
Old Mar 9, 2008 | 04:25 AM
banjopicker
I pulled front tank and replaced pump and the noise is still there, but now i can make it stop by flipping the switch on the dash down and back up, noise stops until i cut it off and restart, looked for a cr**y man but he must have slipped away
ANY IDEAS
Gary
Old Mar 11, 2008 | 02:06 PM
MONTANA350's Avatar
MONTANA350
Maybe you ran over a cat!
Old Mar 11, 2008 | 06:12 PM
66F100Again
I'm kind of guessing here, but maybe it's the switch? When you toggle it, you can get the noise to stop. But if I understand you, when you you turn the key off and back on, the noise comes back? Maybe the default position for the switch it trying to switch to the forward tank?
I wonder if you set the switch to the rear-tank...then disconnect the switch...does the noise go away?
Old Mar 11, 2008 | 11:31 PM
banjopicker
I will try that when i get home
thanks
gary
