Rear Differential Problem - Help
Old Feb 19, 2008 | 12:22 PM
randomhero1172's Avatar
randomhero1172
Hey guys, I have a pretty loud rubbing noise coming from my rear differential. Its not the brakes. Its been like this for about 4-5 days and im taking it in today. What can this be? i dont want to get raked over the coals!
Some info - Doesnt effect performance at any level (accelerating, stoping, 4x4, shifting, trans)
Info is in my sig
How do i know which gears i have?
Old Feb 19, 2008 | 12:50 PM
just another truck's Avatar
just another truck
I cant help you with the rubbing noise, but look at the steel tab on the Diff. You should be able to look it up from the number on that tag. I normally cheat and call the local gear house and ask.
Old Feb 19, 2008 | 12:52 PM
just another truck
Info is in my sig
By the way, were do you plan on going, I would recomend DTS over here on Grosebeck and 696
Old Feb 19, 2008 | 12:57 PM
randomhero1172
Thats right down the road- Im taking it to a guy i know locally west of pontiac. Safety Auto. Hes very honest and says hes good with diesels and knows differentials. He has done stuff for me in the past. Ill call DTS - See what they have to say. They are a real trans shop so they are probably a bit better. Thanks!
Old Feb 19, 2008 | 01:12 PM
just another truck
Good Luck.. let me know how it goes, i will add him to my trust list.
Old Feb 19, 2008 | 01:20 PM
AustinS's Avatar
AustinS
Hopefully just wheel bearings. You could jack the rear up and check each side by pushing top & pull bottom of tire and seeing if there's movement.
When was the last time you checked or changed the rear diff. fluid?
Are there any leaks at the pinion seal? Hopefully it didn't leak and run low.
How are the u-joints on the drive shaft?
Tag on rear diff will have #'s like L 73 105 1C22
L= limited slip
73= 3.73:1 gear ratio
105= Sterling 10.5"
you prob have 3.73 but could be a 4.10
Austin
Old Feb 19, 2008 | 01:24 PM
randomhero1172
U Joints are good. May be the bearings! Well since i purchased the truck used, the last time the fluid was changed was more then 15,000 Miles...So basically i dont know.
No leaks at all - nothing on the driveway or where i park my vehicle.
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
You might try checking the emergency brakes. You did say it is not brake related but I was thinking emergency brakes might be draging on the inside of the rotor.
randomhero1172
Checked em per your advice - They are working fine / not ceased up. Thanks though
