I-Beam Aligning Tool
Old Feb 19, 2008 | 10:52 AM
Boss50's Avatar
Boss50
I was wondering if anyone has ever bent their own I-beam to adjust camber on a king pin axle. I can't seem to find the adaptor for the hydraulic porta-power. thanks
Old Feb 19, 2008 | 12:31 PM
Archion's Avatar
Archion
Veteran: Marine Corps
Last time I had it done, the shop had a frame machine that they used.
Old Feb 19, 2008 | 04:27 PM
Piffery1's Avatar
Piffery1
Most likely cause of camber out of tolerance is sagging (or wrong) springs, worn axle pivot bushings and worn king pins. My alignment man told be that he has never had to bend one of these axles to correct alignment unless its been wrecked, suspension modified, or some other shop bent it (wrongly) to correct a perceived problem. If the ride height is correct then the camber will likely be correct. Sometimes you can install spring spacers to correct sagging springs and restore ride height.
72CC428
23
Nov 26, 2017 08:49 AM
csm_274
Apr 8, 2016 04:06 PM
jack orchard
Apr 3, 2016 11:14 PM
7.3bo-ti-etr
17
Feb 5, 2010 01:44 PM
llehmn
Oct 6, 2005 07:54 PM
