need a alignment with leveling kit?
Old Feb 19, 2008 | 07:59 AM
DaBossF250's Avatar
DaBossF250
Ok, I have a 2007 chevy silverado 1500 4 door. Yes I know its not a ford, but I cannot find any good chevy truck forums. This is the best forum I have found yet! But my problem is similar to the new F150's. My truck sit's higher in the back and low up front. I saw a 2'' leveling kit for like 80 bucks. But my question is, will I have to get the truck an alignment? Or should I be able to put the kit on and be good? And does anyone know whats the biggest tire I can put on my truck with the leveling kit? maybe 305's?
Old Feb 19, 2008 | 08:10 AM
dfishrmn88's Avatar
dfishrmn88
You will need an alignment. The amount varies from truck to truck. Most say the toe in is increased about 1/8" or less with the kit. On mine the increase was 70 degrees or as the tech said, in English 3/4".
Old Feb 19, 2008 | 08:27 AM
mattd17's Avatar
mattd17
i think with the chevy's they use the torsion bars, and your just changing out the cams for it. if so, you may be able to crank your stock cams a bit more, and get to what your looking for.
have you checked this site: http://www.chevroletforum.com/
it about the same... just not quite as good... its hard to top a FORD site !!!
just razzn' ya a bit, but hope it helps/
jct81
Apr 29, 2025 01:36 AM
DvlRacer
Jun 4, 2015 11:01 AM
bth2278
Oct 11, 2013 06:16 PM
onuredneck707
Feb 26, 2011 10:06 AM
bigjack
2004 - 2008 F150
Feb 12, 2004 10:16 AM
