heat
Old Feb 18, 2008 | 11:41 PM
fordlover1992's Avatar
fordlover1992
heat
need to see if any one has any ideas . Have a 1992 f150 put a new thermostat in , flushed the cooling system , and put cardboard in front of the radiator still can't ge the truck to heat up.
Old Feb 19, 2008 | 01:07 AM
jeremiah302's Avatar
jeremiah302
what a coinsadense my is the doing this as well, i was told to check the trap door in the heater box under the dash, if it doesn't open it won't let in the hot air, i haven't done it yet b/c i have something more important to worry about on mine right now, but that is what i was told to do it is right behind the glove compartment. good luck
Old Feb 19, 2008 | 08:21 AM
Conanski's Avatar
Conanski
First check that both coolant lines going to the heater core are hot when the motor is at operating temperature. If they are not disconnect them and flush the heater core with a garden hose, and then reconnect the hoses. If the hoses are hot remove the glovebox and then the core cover behind it and look for a foreign object jambing the diverter door or a broken vacuum line or cable from the heater controls.
toolmaster
Sep 18, 2010 09:41 PM
krave
1978 - 1996 Big Bronco
Apr 22, 2008 07:29 PM
inventor
20
Jun 18, 2007 06:55 PM
ford power 302
Engine Swaps
May 11, 2007 04:58 PM
