Thanks guys. So by those calculations the 265/75r16 is 31.65 and the 275/65r18 is 32.07.
What I'm actually wanting to know is if there will be much of a difference in my final drive ratio if I go with 275/65r18's with 4:10 gears compared to the 265/75r16"s with 3:73 gears that I have now. I thought the taller tires would make up for the lower gear ratio but it looks as if there is not enough difference in tire diameter. 275/65r18 and 4:10's will still be lower geared.
This is exactly what I want. I have the 3:73 now and am perfectly happy with it 90% of the time. There are times when I could use just a little more gear to hold speed in OD. Otherwise I just drop to 4th and let her go. I think the 4:10 with the 18's will do me just right.
