Poor Performance and Erratic Idle
I could really use some advice to a problem I am having with my stock 1989 Ford F-250 with a 351 V8. It runs very poorly under load such as when I gun the engine, pull my boat, or go up hills. It does this consistently.
In addition, on an intermittant basis, it has an irregular idle. I will be stopped at a light and it revs all by itself, as if I'm pressing on the accelerator.
A few weeks ago, the engine stalled out and would not turn back on. Eventually, it started again and it has been running ok (still running poor, but not stalling out) since then.
The check engine light is not on. I took into the neighborhood garage and they checked the fuel pump and spark and said both are good. They couldn't figure out the problem and told me to bring it back when the problem repeated itself. The only thing I have changed so far is the fuel pump. Obviously, this did not fix my problem.
I've checked the archives without success. Can anyone offer any advice?
Many thanks,
Mario
>then.....
I'm betting on the carb - perhaps needs a rebuild...
Many sensors can simply be out of range and send bad data to the processor and still not cause a fault light.
Good luck
Mark
Thanks for all of the advice. I do have EFI so it really sounds like this may be my problem. I bought the Chilton manual at Autozone but this doesn't have anything at all on EFI.
Any ideas for a better aid to help with troubleshooting this problem?
Thanks,
Mario
