302 compression!!!!
Old Feb 18, 2008 | 03:57 PM
COLEYF100's Avatar
COLEYF100
Question 302 compression!!!!
Got a qeustion. Have a 1978 model 302, just checked compression. Motor has 135 to 140 pounds of pressure pure cylinder, but is very weak. It's in a 65 ford f-100, want turn the tires over on a wet road. Also blowing oil up in the air cleaner,can anyone help?
Old Feb 18, 2008 | 04:58 PM
Ultramagdan's Avatar
Ultramagdan
Welcome!
Are you sure it's not a timing issue? I would try this board and post in it: https://www.ford-trucks.com/forums/forum55/ There are some other boards that can help so be sure to click on the Forums tab at the upper left and check them out.
Old Feb 19, 2008 | 08:54 PM
COLEYF100's Avatar
COLEYF100
Thanks I Will Check My Timing.
66shortbed352
New Member Introductions
Jul 30, 2008 04:59 PM
lionel123
Feb 11, 2008 08:23 PM
shackelford
Jan 28, 2008 07:11 PM
Jimmiek
Sep 11, 2007 09:31 PM
bigbobalou21122
Jul 22, 2007 09:02 PM
