Sponsored by: Auxito
Wheel Bearing Question
Old Feb 18, 2008 | 03:08 PM
rlatak's Avatar
rlatak
So I went and had tires put on my 2003 Ford F150 SuperCrew today, and I wanted an alignment along with it. Well when I get back to pick up the truck they say they couldn't do the alignment because the drivers side wheel bearing, and drivers side lower ball joint were shot. Wouldn't there be some signs of a shot wheel bearing. Like make grinding type noises or something. I have not heard anything out of the ordinary coming from my truck. Lets here some feedback. Thanks y'all!
Old Feb 18, 2008 | 03:14 PM
firefighter1416's Avatar
firefighter1416
one would think so, i would try to jack it up and wiggle the wheel and see if there is any play in it.
Old Feb 18, 2008 | 03:26 PM
wesford's Avatar
wesford
It is possible that a wheel bearing could be defective and go un-noticed until inspected, though it's not an everyday occurrence. I agree with firefighter1416.....jack it up and see if there is any play in the wheel. You'll notice even the slightest little bit if there is any. As for the ball joint, it's not uncommon.
96f150's Avatar
96f150
jack up the wheel and grab the tire at the 12 and 6 oclock positions and see if you have any movement.
Rich
Old Feb 18, 2008 | 09:16 PM
steve(ill)'s Avatar
steve(ill)
ball joints probably bad. with tire 2 inches off gound a-frame setting on a jack, pry up with a 2 x 4 under the tire. look for 1/8 inch movement or so in the ball joint, specifically lower. i dont believe the bearing story, they make noise when bad.
