Questions on mounting Guage
Old Feb 18, 2008 | 11:25 AM
seagiant's Avatar
seagiant
Hi
I have a 1989 F-150 with a 300-6 engine and would like to mount a Autometer water temp guage. I just want a single guage and would like some info on where to mount inside cab and how is the best way to get wire inside the cab. Also electric hook up? I know a lot of questions but I'd like to cut down on the learning curve some! Thanks!
Old Feb 18, 2008 | 01:03 PM
DJdemon6696's Avatar
DJdemon6696
best way to get wire inside of cab is tru the PArk brake cable hole.. look for it its under there besides the EEC somewhere.. and i mounted mine here i like it becuase it looks kind of stock and hidden...
electric hook up :
get your 12V for the guage from your fuse box
and ground anywhere you can find a GOOD ground
lights:
i got mine 12v for the light from the ashtray's light it comes on with the dashlights
and i used the same ground
Old Feb 18, 2008 | 01:07 PM
Big_Man_Brad's Avatar
Big_Man_Brad
You can hook up some of the wires to the fuse panel.I'm not sure which ones due to i don't have a aftermarket water gauge...If you don't want to drill a hole in the dash than you have several different pod options...
Old Feb 18, 2008 | 01:15 PM
DJdemon6696
jepp get power from the fuse from the radio and lights and stuff...
Old Feb 18, 2008 | 03:50 PM
seagiant's Avatar
seagiant
Hi Gentlemen,
Thanks for the pics DJ!!! Very nice of you. I've been running around on the Internet and called Autometer about mounting solutions and they make a double guage pod for the trim next to the windshield,for an 89 truck! I might go ahead and put in an oil pressure guage with the water temp. Still looking for info! Thanks to all!
Old Feb 18, 2008 | 04:01 PM
Big_Man_Brad
I have one double pod i would get rid of if you want pm me if you are interested...
DJdemon6696
Originally Posted by seagiant
Hi Gentlemen,
no prob
good idea about that oil pressure and water temp in the pod..
Old Feb 18, 2008 | 04:03 PM
TheRoadVirus's Avatar
TheRoadVirus
I have a dual gauge pod on the pillar (water + oil) and I love it.
Not attached in this pic;
Old Feb 18, 2008 | 04:09 PM
Big_Man_Brad
I got the 3 pillar on my truck...
Old Feb 18, 2008 | 04:46 PM
TheRoadVirus
You need to paint that thing to match your other trim.. I take it completely replaces the old trim piece?
Old Feb 18, 2008 | 04:51 PM
khadma's Avatar
khadma
Carpenter Local 745
I gotta see if Autometer makes pods for 07 Explorers. My Explorer has no oil pressure gauge!
I have a two qauge pod in my 96 FSB - trans temp - engine oil temp.
Old Feb 18, 2008 | 05:08 PM
Big_Man_Brad
No it didn't replace the old trim..Yeh i know i gotta paint it but its way to cold to paint things right now..
Old Feb 18, 2008 | 07:04 PM
seagiant's Avatar
seagiant
Hi Brad,
I'm interested but need to make sure it will fit a Ford 89 F150! The site will not let me PM you. My E mail is seagiant@gobigwest.com.
Thanks for the pics gentlemen this is great. I am defiently going to do this mod!!!
Old Feb 18, 2008 | 08:09 PM
flareside_thunder's Avatar
flareside_thunder
Jurgen and Travis...how did ya'll hook up your water temp?I've got a fuel pressure a water temp and an oil pressure...the oil is the only one that works and I'm gonna replace the fuel with a tranny temp gauge......If ya got pics even better...
JR
Old Feb 18, 2008 | 08:17 PM
DJdemon6696
JR
for the 12V ive already posted...
hmm i comes with a sender and you install that where the old sender is.. but i replaced the old sender with the one from the autometer one .. so my stock dash guage doesnt work, only the aftermarket one... you can make a T fitting and fit both... its up to you..
the sender is behind the distributer on the driver side you cant miss it
