New Lift ordered!!
Old Feb 18, 2008 | 09:55 AM
UP_There's Avatar
UP_There
New Lift ordered!!
It's on it's way.....my truck will be a bit higher in the next few days. Pro Comp 6 inch spring lift front and rear is on the way! To be more specific....the lift I have now is sorta pieced together. I have a 2 1/2" leveling kit, in front with add-a-leaf and re-arched springs. Rear is 4" block. Gives me approximately 5" of lift. I will be leaving the 2 1/2" spring hanger kit on the front, and adding 4" Pro Comp springs in front, and 6" springs on the rear, along with a 6" drop pitman arm, and track bar drop kit to line everything back up where it belongs.....so my truck should be a 6 1/2" lift when it's all said and done! Axle wrap has been a MAJOR problem having the 4" blocks in the rear, looking forward to having all spring in the rear......I can get better traction for the DP Tuner that will be ordered as soon as I get the BTS Valve body! I'll post pics after the lift is installed
Old Feb 18, 2008 | 10:35 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
You will notice a definite improvemnt once you get rid of the blocks in the rear. More power to the ground and less wrap. I ditched my block set up back in September and went with Pro-Comp lift springs in the rear. I run Superlift springs in the front.
Old Feb 18, 2008 | 03:28 PM
UP_There's Avatar
UP_There
So do you get any wrap whatsoever with all spring on the rear? I'm hoping I don't....not real crazy about running a traction/ladder bar. Most of those take away from ground clearance!
Old Feb 18, 2008 | 04:16 PM
Texas Outlaw
Not a liberal...
No, I get power straight to the ground. I am only lifted 4" though. Not sure if going higher could let the axle wrap a little or not.
Old Feb 18, 2008 | 08:19 PM
Benny2002's Avatar
Benny2002
I too run superlift in the front and procomp in the rear. Have been running the procomps for not quite a year and i run my truck everyday at near payload capacity in the bed. They havent sagged at all i am impressed especially for the price. I run 6in, i had to shave off the last little angle spring shim on the rear to get the pinion-pumpkin to line up with the driveshaft just right. I no longer have axle wrap either and it was pretty bad before with blocks. With 3:73s i dont think you could get wrap out of the six inch rear spring, maybe 4:10s
Old Feb 18, 2008 | 09:36 PM
sflem849's Avatar
sflem849
With all those parts installed there must be a stock leveling kit for sale???
Old Feb 18, 2008 | 09:42 PM
UP_There's Avatar
UP_There
The leveling kit is actually the only part that is staying on.......as stated in my original post. I will have the springs and blocks to get rid of though.....
Old Feb 18, 2008 | 09:47 PM
sflem849's Avatar
sflem849
You know me and lift kit stuff....zooooom......over the head. All I know is my truck points down hill and I don't like that
Old Feb 19, 2008 | 08:33 AM
haulingboat's Avatar
haulingboat
Sorry for my ignorance but what is axle wrap?
Old Feb 19, 2008 | 09:01 AM
UP_There's Avatar
UP_There
axle wrap is caused when you lose traction on the rear wheels. With lift blocks....it actually lets the axle rotate from the torque, and your rear wheels, and basically the whole back of the truck will HOP up and down! It's extremely annoying, and really hard on the driveshaft. If I'm in 2wd while offroad, and get into any type of loose dirt on a climb....the truck is worthless. It will start hopping up and down pretty bad. Gotta just stop and put it in 4wd. I'm really hoping that all spring lift in the rear will cure this COMPLETELY. If not.....I'll be going with a traction/ladder bar.
Old Feb 19, 2008 | 09:03 AM
jeepster1272's Avatar
jeepster1272
Axle Wrap is when your axle will tweak foward or back under load, or even hop. I used latter bars with no clearance issues.
Old Feb 19, 2008 | 10:29 AM
haulingboat
Got it. Thanks.
Old Feb 22, 2008 | 12:03 PM
UP_There's Avatar
UP_There
Ugh! Just called my lift guy checking on the parts.....and only the springs are here, the other parts should get here on monday....this is TORTURE! I'll have it installed by the end of next week though
Old Feb 22, 2008 | 02:00 PM
03_PSD's Avatar
03_PSD
the suspence...make sure you got that camera handy
Old Feb 23, 2008 | 12:43 AM
UP_There's Avatar
UP_There
the shop called me today.....IT'S IN! Now I just need to get it in there next week. Gonna be a long weekend haha
