New Lift ordered!!
Old Feb 24, 2008 | 06:31 AM
schmuly's Avatar
schmuly
Thumbs up
Hi are your old rear springs stock? If they are , are they a A code or B code. I am looking for B code springs. Thanks
Schmuly
Old Feb 24, 2008 | 07:14 AM
UP_There's Avatar
UP_There
I'm not sure which type they are, I will know once they get pulled off. The fronts have been re-arched. And the rear has been used with a 4" block. I will definitely be letting the stuff go for very cheap once I get it off!
Old Feb 24, 2008 | 09:04 AM
schmuly's Avatar
schmuly
I changed my fronts and it was tricky for one person because of the weight, involved, haven't tackled the but should not be as hard.
The spring code is on the info sticker on the door jam. On the lower right hand corner it will say SPR and underneith it will have a two-character code, eg. VA or VB The first is for the front and the second is for the rear. I hope this helps.
Colin
Old Feb 26, 2008 | 12:28 AM
UP_There's Avatar
UP_There
Well it's getting installed on wednesday! Pics to come shortly!
Old Feb 26, 2008 | 03:28 AM
ron's power stroke's Avatar
ron's power stroke
good luck and have fun...
Old Feb 27, 2008 | 09:46 AM
UP_There's Avatar
UP_There
the truck is getting the lift installed RIGHT NOW. If I wasn't watching my daughter all morning, I'd be down there lurking The suspence is killing me!!!!!!!!
Old Feb 27, 2008 | 04:39 PM
UP_There's Avatar
UP_There
Couple more hours to go!!!!
Old Feb 27, 2008 | 04:48 PM
schmuly's Avatar
schmuly
Thumbs up
Pic looks great , I found some B-code springs locally. I thought i would grab them as they are hard to comeby up here. Good luck with yours.
Colin
Old Feb 27, 2008 | 04:51 PM
UP_There's Avatar
UP_There
Hey Schmuly.....I guess I am my own thread.....but what exactly is the difference between A and B springs?
sflem849's Avatar
sflem849
When I see the truck like that I start thinking matt tracks...
Old Feb 27, 2008 | 04:53 PM
sflem849's Avatar
sflem849
The FD just to the south of us has this truck. They already threw a track once and RIPPED apart a fender going through a ditch. Plus they can't use the truck on the road full of water bc it will void the track warrenty....
Old Feb 27, 2008 | 04:55 PM
UP_There's Avatar
UP_There
WOW.......cool idea, but not much for ground clearance!!!! I wonder what is the purpose of a Fire Department using it??
Old Feb 27, 2008 | 04:58 PM
  #28
schmuly's Avatar
schmuly
A-Code = 6,084 # rating
B-Code = 6,830 # rating
C-Code = 8,250 # rating
Colin
Old Feb 27, 2008 | 05:21 PM
  #29
deemac's Avatar
deemac
I have the pro comp 6.5 all spring kit in my truck...and i love it. It rides a little rougher than stock but that just helps you remember your driving a truck. I've driven a couple chevys with lifts and its as smooth as a honda civic, i want my truck to feel like a truck. Oh and i dont get any axle wrap either. I run 37" toyo's and i have the dp tuner too. The pro comp kit is pretty good. The front has sagged a little bit but not bad. You'll love it.
Old Feb 27, 2008 | 05:24 PM
  #30
UP_There's Avatar
UP_There
Deemac.....you're killin me! You need pictures in your gallery! I could almost visualize my truck if I saw yours right now hahaha
