First post: Problem with dual tank question.
Old Feb 18, 2008 | 12:55 AM
papamojo's Avatar
papamojo
Love this site. Did a search but cant find an exact match to my issue. I just picked up a nice 87 F250XL with a 460 in it. It has dual tanks. They guy I bought it from said to use rear tank only as front tank has problem. The strange thing is if I leave switch in truck on lower (rear) tank position the electric pump continues to operate even when key is out and power is off. I have to put switch up (front tank) posistion when I get out of truck.
When I am driving and I test switch by changing from rear tank to front tank the truck will die from no gas.
Does this sound like the switch or one of the 3 fuel pumps? Whey would it keep working with key off>?
would this be an easy fix>?
Also, The gauge reads well over full when full(yes I have read this is normal) however I use more then a third of tank before it gets below F on gauge.
Thanks!
Old Feb 18, 2008 | 04:49 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
First off, Welcome to FTE!
It sounds like the switch is working, And the rear pump is ok. Since I don't have FI I'm not too familar with the 3 pump system. Wondering why it can get power key off. If the PO hasn't hacked the harness, I'd suspect a sticking relay.
There are others here with intimate knowledge of the wiring. I'm sure someone will chime in soon.
Also, The gauge reads well over full when full(yes I have read this is normal) however I use more then a third of tank before it gets below F on gauge.Thanks!
Senders are notoriously sketchy, mine does this too.
Old Feb 18, 2008 | 11:48 AM
papamojo's Avatar
papamojo
[QUOTE=ArdWrknTrk]First off, Welcome to FTE!
Thanks! Hope someone can help!
Old Feb 18, 2008 | 12:32 PM
quicklook2's Avatar
quicklook2
sounds like front tank pump is not working.
Old Feb 18, 2008 | 03:22 PM
hunter_firefighter's Avatar
hunter_firefighter
try testing the fuel pump relays sounds like it is stuckin the on position , if this is the case the reason it shuts off when you switch to the front tank is the front pump is not functioning
