flattops AND aussie's?
Old Feb 17, 2008 | 06:07 PM
dutchlincoln79's Avatar
dutchlincoln79
hello,
When i opt to throw in some KB flattop pistons as showed at Tims website, i should get 10 to 10.5 :1 compression with stock heads, right?
Is it then possible, in the future, to still put some aussie heads on them in order to get the CR still higher?
or would i be banging my valves then?
i'm looking for a way to increase CR significant now (on a budget) and MAYBE do some more in the future, without disassembling everything again.
Also, would the $150 KB hyperteutic flattops fit right into my engine? Same pin's etc.?
Can it be done by myself, being not an idiot with 2 left hands, but not a daytime car mechanic also?
thank you.
regards,
Stef.
Old Feb 17, 2008 | 06:12 PM
Winder's Avatar
Winder
Yes that will give you a boost in CR. What kind of fuel are you going to run?
Old Feb 17, 2008 | 10:44 PM
dutchlincoln79
99.9999% of the time i will run propane/butane 40/60, thats what's propane called in the netherlands.... In the winter, they turn the mixture in 60/40.... Not purely 100% prop. unfortunately..
but... it'll do.
For the other .0001%... Well, octane premium is here 93 (it's 98Ron, but measured differend as i understood correct, so it comes at 93..)
Old Feb 18, 2008 | 06:05 AM
Kionga's Avatar
Kionga
Re: Flattops and aussies
Hello Steph.
I would be cautious about raising the CR too high. My experience shows that at CR 10.8:1 with open-chamber 2V heads detonation is a real possibility, especially where the cam is inappropriately chosen. My initial cam in a 400 was fine because I had a longer exhaust duration: the next cam built cylinder pressure too high and too rapidly leading to detonation-even with pure propane, although not as pronounced as with propane/butane mixtures.
To be honest, you should aim for 10-10.5:1 CR with closed chamber 302 aussie heads, given the lack of access to straight propane. This should give you Steph a Lincoln with great bottom end and reasonable running costs. And with a good margin of safety should they stuff around with the percentages of propane/butane-not an uncommon situation here in AUS.
Hope this helps.
Craig
Old Feb 18, 2008 | 06:08 AM
dutchlincoln79
ok.
Isn't it better then to go with the flat tops alone, getting 9.5 to 9.8:1Cr and leave the heads stock?
It's the cheapest way i guess?
i was thinking 10 to 10.5:1 with the flattops, but that's with the special made high-dollar pistons.
Tip said that the $150 set pistons, KB flattops, would raise it to 9.5:1
When i add a little bit of deck milling, i come to 9.7-9.8:1 i guess?
Old Feb 18, 2008 | 07:52 AM
hollenjoe's Avatar
hollenjoe
I milled my heads by .020" and got around 9.9-10:1 Im running a big cam and im still worried bout detonation..... although thanx to alcohol i get to choose from 91 octane and 98......
Old Feb 19, 2008 | 12:26 PM
MOB.Diesel-350's Avatar
MOB.Diesel-350
I would try to keep the bottom end alone if nothing is wrong with it. i was goin to put a set of aussie heads on and call it a day, but then i sold the truck. . . which reminds me, i have a set of aussie's in the garage i dont need anymore.
Old Feb 19, 2008 | 12:58 PM
dutchlincoln79
Friend
Can you PM me some pictures of the aussies?
Are the cast, or alloy?
what rockers are on them?
Stud's or pedestal?
Thanks.
stef.
Old Feb 20, 2008 | 12:48 PM
MOB.Diesel-350
they are bare heads. as far as i can remember, the sock valvetrain will transfer directly onto the aussie haeds.
Old Feb 20, 2008 | 12:50 PM
dutchlincoln79
Do they have studs, or are they pedestal?
Old Feb 21, 2008 | 01:18 AM
MOB.Diesel-350
i do not recall. will check it out and let you know.
Old Feb 23, 2008 | 11:22 PM
MOB.Diesel-350
got pics of them on my gallery. i believe they are pedistals.
Dobies4life
May 23, 2013 05:16 AM
clawhammer
May 23, 2008 05:57 PM
debestuss
30
Nov 22, 2004 07:20 PM
satx77stepside
Nov 10, 2003 07:25 PM
Brian460
Exhaust Systems
Sep 4, 2002 10:36 AM
