Head gasket or Intake gasket?
Hi all need some help here.
I put an 84 LTD 400 motor in my 79 f150 truck last year. So far it has been running great, and still does but, when checking the oil the yesterday i noticed a little antifreze, when i smelled the oil it smelled like gas. My question is would it be my head gasket, or my intake gasket, or could it be both? How would i be able to tell which head, or if it is the intake without a leak test, as i dont have or know anyone that has a leak tester. Any info would be of great help. Thanks in advance for any replies.
Six strings and Ford trucks music to my ears
79 F150 400 T18 9in 2wd
97 F150 4wd 10th scale remote control 50 mph to cool
I think the 400 has a dry intake, no coolant passages, so my guess would be a head gasket. You could always pull your plugs and see if any show signs of foreign substances. Best test would probably be a compression check. If it's bad enuf of a leak you can pull the fill cap off the valve cover, squeeze the upper rad hose and you'll be able to hear the water squish I found that out the hard way on a tempo I use to own
mrl390
13
09-09-2007 11:50 AM
