i pulled off the oil pan and im not sure what motor i have. it is a 79 250 4x4. the connecting rod caps have an "s" stamped in them. the bearings have 4-79, d.a.b., d0ae-6211-a-b, the caps also have "d1ae" stamped. the main bearing cap has a "k" sstamped in it. the main bearing is stamped "d.a.b., 2-79 L, d7ae-6a338-aa-ba. i dont know where to look for numbers on the crank itself.
The casting code for the crank is located on the first counterweight. It should be a 5M, 5MA or 5MAB if it's a 400 or 1K if it's a 351M.
